    Evening members,
    Iíve watched the forum for about 6 months now and come back for information and such like,
    Little about me, hmmm im a young lad from East Yorkshire between York and Hull, Even at my age i have saved a nice capital amount of money to go and look at setting up as a cnc contractor, while prototyping/developing some items of my own that i have been drawing and planning for 2 or more years.
    Iíve been helping/hindering/learning from a friend that runs a Haas tm3 and a tl1 as a hobbyist.
    So with the Haas and other cnc experience Iíve gained running other machines, i have decided to setup offering cnc contracting in a range of fields.
    Taken on a 1000sq unit local to me, my "plan" is to purchase a dmg mori seki lathe with a bar feed and a mill most likely from hurco/haas or if i can push for work then will consider a mill from dmg if the works there.
    As per usual with everything its depending if i can source work for them (chicken and the egg!) if worse case itís a no then im already a coded welder so will stick with light fabrication as a main rather than side job.
    Think thatís a good enough introduction if not ask and answers will be posted.
    Ben
    Hi Ben
    Welcome to the forum
    Good luck with your new venture hope everything turns out ok for you.
    Andy
    Quote Originally Posted by audioandy View Post
    Hi Ben
    Andy
    Cheers Andy,
    You me both!
    Ben
  1. NEW MEMBER: Hello from the south east!
    By cncJim in forum New Member Introductions
    Last Post: 10-06-2013, 09:14 PM
  2. NEW MEMBER: Hello from East Sussex
    By meyerga00 in forum New Member Introductions
    Last Post: 12-12-2010, 06:55 PM
  3. NEW MEMBER: Hi from Yorkshire
    By Graham in forum New Member Introductions
    Last Post: 28-04-2009, 12:39 AM
  4. NEW MEMBER: Hello from Yorkshire
    By potter1932 in forum New Member Introductions
    Last Post: 28-06-2008, 10:00 AM
  5. NEW MEMBER: NEW MEMBER FROM EAST YORKSHIRE
    By shamus13 in forum New Member Introductions
    Last Post: 19-02-2008, 05:19 AM
