    What is involved in converting my ER16 2.2KW spindle to an ER20 type?
    ...I didn't expect to use many 1/2 inch shaft bits at the time I bought it, and now I have one!
    Alternatively, could someone reduce the shaft on the bit from 1/2" to 10mm? It's a large 45deg V Groove cutter.
    It's basically not realistic. Since the ER20 taper is bigger than the ER16 you would have to get a new spindle shaft made, which is going to cost a huge amount.
    Some sort of 10mm to 1/2" adapter would work, but you would have to be very careful on how big a cut you take with that as it wont be very strong unless supported by another bearing.
    JAZZCNC's Avatar
    Lives in wakefield, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 6-7 years. Has a total post count of 6,205. Received thanks 1,015 times, giving thanks to others 42 times.
    Not worth the trouble you can buy a good quality TCT V cutter with 1/4" shank for 23. It would cost at least half this to have some one do it then you have the wait etc.!
    http://www.wealdentool.com/acatalog/...roove_285.html
    Thanks Jazz, I've ordered one. I couldn't find any with a significant depth of cut with a 1/4" shank.
    ...now I have an expensive 1/2" shank bit to get rid of!
    Last Post: 26-11-2016, 06:25 PM
  2. FOR SALE: ER20 DIY Spindle Parts
    By Mad Professor in forum Items For Sale
    Last Post: 03-11-2012, 05:51 PM
  3. FOR SALE: ER20 collet set 12pcs (2mm-13mm)
    By rbs in forum Items For Sale
    Last Post: 17-06-2012, 01:07 PM
  4. WANTED: ER20/25 straight shank collet chucks
    By m_c in forum Items Wanted
    Last Post: 24-10-2011, 11:19 AM
  5. ER20 Collets
    By audioandy in forum Tool & Tooling Technology
    Last Post: 05-08-2009, 09:15 PM
