Page 3 of 3 FirstFirst 123
  1. #21
    You don't need to use CY cable for your limits assuming it's a 24v circuit. I would use twin cable and bring them back to a junction box where you can series them up. If later on you want to change how they are connected then you won't need to rewire them, just change how they are connected in the junction box. The limits circuit is low current and low voltage so I plan to use twisted pair CAT5 cable, because it's twisted it is effective at screening out noise.
  2. #22
    My only caution is that CAT5 cable tends to be single core and that would not be suitable for constant flexing. You would have to use the type suitable for patch cables. I wish I had thought of it, I have an oudle of it (15+ metres) and I bought cable from BRIMAL (Welcome to Brimal Components) They have a good range of interesting bits at keen prices.
  3. #23
    Thanks guys. Just another stupid question: as the x axis is slaved do I only need limits on one side only or both. I have homes on both to ensure the gantry is squared.
    Dan
  4. #24
    Quote Originally Posted by Danielroyal25 View Post
    Just one Side Dan. Think about having the Switch travel on the gantry with Triggers at each end to save on wiring and switches.
  1. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC/EMC
    Last Post: 15-10-2014, 08:51 AM
  2. 24v Limit/Home switches. How to..?
    By Wal in forum General Electronics
    Last Post: 17-11-2013, 04:52 PM
  3. Limit Switches with LED's
    Last Post: 02-01-2013, 02:08 PM
  4. Limit/home switches - how are you mounting 'em?
    Last Post: 13-11-2011, 12:42 PM
  5. The best solution for limit / home switches on a mill is .....what ?
    By NICKMODELMAKER in forum Gantry/Router Machines & Building
    Last Post: 29-05-2010, 12:38 PM
