    I've read that 5mm seems to be the preferred size for pulleys, is there any specific reason for this? Would 3mm (15mm wide) cause any problems as I cant seem to squeeze 5mm pulleys (20t &40t) into the space I have available while keeping the number of teeth engaged at a reasonable number.
    Any thoughts?
    Quote Originally Posted by mocha View Post
    Mainly because there more common and cost effective.! . . . 3mm will be fine so long has the belt width and engaged teeth is kept.
    Thanks jazz, 9 and 22 teeth engaged on the 20t and 40t pulleys... should be enough for Z??
    Yep thats fine.!
  1. Ballscrews - pulleys - timing belts
    By vre in forum Gantry/Router Machines & Building
    Last Post: 15-01-2014, 07:03 PM
  2. Belts & pulleys,
    By jcb121 in forum Belt Drive, Pulleys & Timing
    Last Post: 28-09-2012, 11:32 PM
  3. Belts and pulleys calculators
    By mocha in forum Belt Drive, Pulleys & Timing
    Last Post: 26-07-2012, 01:52 PM
  4. Belts & pulleys & advice please
    By CNCBlug in forum Belt Drive, Pulleys & Timing
    Last Post: 29-04-2012, 09:31 PM
  5. Source for XL timing belts and pulleys
    Last Post: 20-08-2009, 12:21 PM
