    Hi folks
    I need custom desgined newel posts with a diameter of approx 100mm and length of approx 800mm.
    Ideally, I'd prefer these posts to have two motise joints before they are cut to shape.
    I've been in search for a cnc woodturning lathe but the prices are crazy!
    Can any1 help?
    This could be done on a cnc router with a 4 (rotary) axis. How many posts are you thinking of as it may be quicker just to turn them on a manual lathe.
    Bruce
    The more I know, I know, I know the less. (John Owen)
    Hello
    Yeah, its possible to do this on a cnc r axis.
    Well i need an initial order of 20 posts. Will it be possible to replicate these on a manual lathe?
    Depends on the complexity of the item. Copy lathes are not uncommon and were designed specifically for work like this. have you got a design that we can see?
    Replicating these on a manual lathe can be done but you will need to find a very good turner. A copy lathe would be the way to go to get accurate copies. Any differences in the copies would be noticeable when the posts are close together.
    Quote Originally Posted by dopamine View Post
    Hi folks
    Can any1 help?
    From your request I can only assume the mortices are to be in a circular section of the newel. If they are to be in a square portion, as is usual, I'd recommend the mortices be chopped out after the turning is complete.
    How many are needed and what material?
    Quote Originally Posted by boldford View Post
    I need an initial order of about 20.
  1. RFQ: Woodturning project
    By dopamine in forum Projects, Jobs & Requests
    Last Post: 16-03-2013, 11:19 AM
  2. NEW MEMBER: New Member from Across the Pond-and an Introduction to My CNC Lathe Project
    By acollins in forum New Member Introductions
    Last Post: 13-05-2012, 09:14 PM
  3. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 09:45 AM
  4. Woodturning on CNC lathe
    By Minnican in forum Woodwork Discussion
    Last Post: 26-02-2011, 12:30 PM
  5. Project IceMould.
    By NC-Joey in forum Gantry/Router Machines & Building
    Last Post: 11-08-2007, 06:00 PM
