    Navigate to Start -> Run and type diskmgmt.msc in the dialog box then click Ok
    From the disk management window, right click your flashdrive and select the option to Delete Partition:
    Right Click your flashdrive again and select the New Partition option:
    Follow the New Partition Wizard and create a "Primary Partition". Once you get to the dialog box to set the Partition Size, be sure to set the Size to be smaller than the drives capacity to leave free space for the next partition:
    Continue through the Wizard, giving your device a drive letter and formating the partition. I recommend a Fat32 partition.
    After you have created the first partition, you can create additional partitions using step 3-5 on the unallocated empty space that remains on the drive:
    Once finished, you should have multiple partitions on your USB flash drive that are detected and usable in Windows as separate drives.
    Enjoy!
    .Me
    .Me
  1. Flash POP Warning
    By longy in forum Metalwork Discussion
    Last Post: 18-03-2014, 09:45 PM
  2. Windows Xp: Any USB Flash Drive As A Local Disk
    Last Post: 04-07-2010, 11:38 PM
  3. Mach 2 / 3 - Windows 2000/XP
    By teetat in forum Artsoft Mach
    Last Post: 10-07-2009, 01:47 PM
  4. FAKE FLASH ON EBAY - Advice + Test Program !
    By Lee Roberts in forum Marketplace Discussion
    Last Post: 17-12-2008, 04:35 PM
  5. eBay: 2GB USB Flash Memory, Swivel Stick (black)
    By Lee Roberts in forum Items On eBay UK
    Last Post: 17-12-2008, 04:34 PM
