    hmm, anyone good with ratios for rpm etc?
    Im looking at this spindle, and trying to figure out how much rpm I will get from the 4000 rpm motor, spindle is very thin compared to stock
    DJH
    DJH.
    I have a Taig here and will measure the pulleys later and work out what the various spindle speeds are.
    Can I query your motor being 4,000 rpm ? I was led to understand that the Italian motors supplied with a Taig were 2,850 rpm ?
    Ratio's are just a division of driver over driven multiplied by motor speed so a 100mm motor pulley driving a 50mm spindle pulley will be 100 / 50 = 2 x motor speed, if it is a 2,850 motor then spindle will be doing 5,700
    John S.
    John S -
    well ive not measured it, sorry I meant it drives the spindle at around 4000RPM or so i was told, perhaps you can shed some light on it.
    I can't tighten my belt much as im struggling to get the thing aligned enough so it does not make a load of noise when tightened.
    do you know of any decent motor upgrades? I may have to upgrade to a Kress, but as I bought the ER-16 spindle I would rather stick to the belt driven system with a faster motor.
    DJH
  1. New Build Advise Ive Got Myself So Confused ! Please Help !
    By grain_r in forum Gantry/Router Machines & Building
    Last Post: 26-07-2014, 12:21 PM
  2. Advise on building a CNC table
    By T0rnado69 in forum Gantry/Router Machines & Building
    Last Post: 30-06-2014, 10:19 PM
  3. Router has died. Need Advise Please.
    By Bush Flyer in forum Spindles & Drive Motors
    Last Post: 09-03-2014, 12:42 AM
  4. I need advise again
    By habibuzziwa in forum General Discussion
    Last Post: 08-10-2012, 09:08 AM
  5. I need advise
    Last Post: 03-10-2012, 09:50 AM
