Page 2 of 2 FirstFirst 12
    MATT's Avatar
    Lives in Brisbane, Australia. Last Activity: 05-08-2012 Has been a member for 6-7 years. Has a total post count of 2.
    Quote Originally Posted by mocha View Post
    Here's a topical but tricky question for the illuminatti that keeps coming back in various guises:
    Assuming the budget will not stretch to ALL of the following features, which one (or two) would you choose to compromise on?
    Welded steel framed gantry
    20mm alloy Z and Y axis
    Water cooled 2.2kw spindle and VFD
    M542 drivers
    50v power supply
    1610 ballscrews
    20mm supported rail
    variable height table
    Unsure on how you budgeted for all the above items, but I need to ask how you intend to, or what you mean by variable height table.
    I am also building one with a variable height table (large scale things donít need as much rigidity, whereas steel does so tighten up the size and specs for cutting smaller steel parts).
    Only now I am nearly finished it, I wish I had compromised on the space of the X axis and had a moving X table with a fixed YZ gantry that could be dismounted and adjusted up or down) instead of moving the whole fixed bed up and down. But sometimes you got to learn the hard way (I was told, but am always too stubborn, haha).
    Have fun, and let us know how it goes, I will post my machine once the frame is welded.
    Quote Originally Posted by wilfy View Post
    so what decides how you choose the right size motor? i presume weight of what you are driving comes in to it.. does the size/weight of the screw come in to the decision? does the materials to be cut have any sway on it? i also dont understand how the word resolution is used in cnc.. my thoughts are it is similar to a picture where there are so many dot's making curves smoother, does the same thing happen when you lose resolution in cnc? you start to get blocky curves?
    Can't really Add more to what Irving already said but I would like to comment on this portion of what Irving said.!
    At 600rpm theres going to be relatively little torque available so there is a danger of losing steps... its all a balancing act :)
    This comment I don't agree with and is not my experience.? Stepper motors using higher voltage giving best performance will easily work at 600RPM and have a usable amount of torque available, they certainly won't be in danger of losing steps unless cutting really hard and deep or moving/stopping heavy weight around fast.!
    Irving's correct that it's a balancing act and very important you consider what you want the machine to do and the feedrates required, then use this information in conjunction with machine data like weight to Accelerate and de-accelerate to aid select correct screw/motor/drive/PSU choice.
    All this said when it comes down to it selecting Screw/motor/PSU etc there's only so many options for a given size/style machine doing certain kind of work.? So don't rack your brains trying to figure what's needed just browse the forum's find a similar size and type of machine that looks like it works how you'd like and ask what they use.?
    Think you'll find it boils down to only a few options for good quality accurate machine. Like these.!!
    Small moving gantry woodworking/plastics only machine: 10mm pitch ballscrews, 1.85Nm, 50V drive, 40-45VPSU
    Medium to large moving gantry woodworking/plastics only: 10mm pitch ballscrews 3Nm, 75V drive, 65-70VPSU
    Small all round material moving gantry machine: 5mm pitch, 1.85Nm, 50V drive, 40-45VPSU (10mm pitch option costing resolution/torque which is usually preferred for Alu or higher detail work.!)
    Medium to large all round moving gantry material: 5mm pitch, 3Nm, 75V drive, 65-70VPSU ( 10mm pitch is high consideration on this larger size machine and the trade off between loss resolution/torque and speed gain can be justified to a degree.?)
    Fixed gantry machines can get away with using slightly smaller motors due to less weight being shifted and the fact they tend to be smaller machines anyway because of the room they take up (basicly double the cutting length or width).
    Mostly you'll find fixed gantry machines are built for strength and resolution so don't need high feed rates so use high lead screws which give much higher torque.
    so.!. . . 5mm pitch/1.85Nm/50vDrive/44-45v is common. With high detail and really low pitch screws then lower powered motors/drives etc can be used.
    These examples presume ballscrews and decent supported linear rails if other methods are used then these options could change slightly with chance the motors/drives/psu may need upgrading to over come the higher friction with some methods.?
    Then there's the Milling machine/lathe conversions which play to different tunes and very dependent on machine so won't go there.!
  3. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  4. #13
    Quote Originally Posted by MATT View Post
    I am also building one with a variable height table (large scale things don’t need as much rigidity, whereas steel does so tighten up the size and specs for cutting smaller steel parts).
    Hi Matt
    In this context, it's a hypothetical question. It supposes that you are in the planning stage of a CNC build and that the feature list of the desired machine had those items in it. It also assumes that the budget can not be stretched, cajoled or persuaded to pay for all of them. So, which would be the areas that could be compromised with the minimum effect or to put it another way, for the benefit of those yet wanting to do a build but thinking they don't have the cash; what priority to give to the various elements. My initial design criteria were none of the above and my plans don't include any of those features. The width of my shoulders, the doorway is needs to go through and the price of jaffa cakes were higher on my list. :-)
    For me the answer was simple, wait until I can afford to get the bits that I wanted. Simple but difficult if you see what I mean.
    There are some great methods in other threads showing how the question of raising the bed can be accomplished, jazz posted a link for a good one as I recall. I went for an asymmetrical bed that I could just flip over and get different heights but if I was doing it again, I'd have a longer look at a packing system to lift the work to the optimum height.
    Look forward to seeing your pics too.
  5. #14
    There's only one and that's the table.!! . . . Some times people need to accept they can't afford to build just yet and save up a bit more.!
    99% More often than not if they do proceed before ready it does cost them much more in the long run. . :(
    This isn't always a bad thing though if I knew how much the router was going to cost when I started I probably wouldn't have done it BUT I'm so glad I did!
    You don't count the cost on this one ;)
    Why would you want a variable table height? Seems to me that's just more hassle than it's worth. I'd just move the gantry up and down instead with dual ballscrew and slides if rigidity was that essential.
    I have toyed with the raising and lowering the gantry instead of just the spindle I should make a decision I guess lol since I want to start the ball rolling with making my mounts now.
    The biggest hassle for me is because I'm using toy electronics (Arduino, cncshield, cheap ass steppers) is I would have to wire 2 steppers to 1 socket so I can have a dedicated stepper for each motor not rocket science just hassle. Or Buy better steppers and wire them to the Arduino.
  6. #15
    Lives in East Lothian, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,192. Received thanks 245 times, giving thanks to others 5 times.
    Desertboy, is there any thread you've not pointlessly resurrected yet?
  7. #16
    It's because it makes suggestions in the bottom right corner and I never notice the dates lol. Rather than I'm trying to resurrect 5 year old threads
  1. Nitrile O-ring belt drive - suggested stretch percentage..?
    By Wal in forum Linear & Rotary Motion
    Last Post: 13-05-2014, 11:49 PM
  2. Commercial Machine choices...
    By jashington in forum Marketplace Discussion
    Last Post: 10-10-2013, 10:38 AM
  3. Drowning in choices for my plasma table project
    By SemiSkilled in forum Plasma Table Machines
    Last Post: 22-09-2013, 07:10 PM
  4. Which spindle with a £200 budget?
    By fasteddy in forum Marketplace Discussion
    Last Post: 29-06-2010, 11:51 AM
  5. Choices ...
    By Wobblybootie in forum Computer Software
    Last Post: 13-01-2010, 03:22 PM
