    I was about to buy some 8/6 mm pvc hose and saw some one talking about 5/7mm. Which do you use?
    Bruce
    The more I know, I know, I know the less. (John Owen)
    8 mm .
    Can't see it being that critical, they only need a dribble of water and it's under pressure anyway.
    John S -
    Thanks. Ordered
    Thanks Jonathan for the 8mm dimension, maybe I'm being thick, but is that the inside diameter of the Hose? Also is this a standard size to fit directly onto the pump outlets?
    John mentioned, the system will be under pressure, so will I need jubilee clips on the hose at the pump side, or is the hose a very tight push fit?
    From a lot CNC builds I've seen, people have a blue liquid in the coolant system. What is this, standard automotive anti freeze?
    Adil
    Quote Originally Posted by Iwant1 View Post
    It will be ID but That depends on the spindle to some degree.? I've had spindles with 6mm & 8mm barbs so check your spindle.
    The pump depends.? Most I've had needed step down adaptors from 1/2" to 6 or 8mm. Any decent tropical fish place will stock these.
    Again depends how you do it.? If you just choose the simple method of dropping submersible pump in tank of water then the pressure is virtually nothing.
    If on the other hand it's a sealed system then the pressure will be what the pumps rated at.?
    I use the simple method the water is Distilled water with Decent anti freeze 60/40% mix.
  1. Spindle water hose connector
    By cncJim in forum Marketplace Discussion
    Last Post: 20-02-2014, 10:22 AM
  2. Do you need to water cool erhm a water cooled spindle?!!
    By HankMcSpank in forum Generic Chinese Spindles
    Last Post: 02-10-2013, 08:59 PM
  3. Replies: 17
    Last Post: 18-09-2013, 05:32 AM
  4. Spindle Water Pump
    By Tomnewry in forum Spindles & Drive Motors
    Last Post: 11-08-2013, 12:05 PM
  5. water cooled spindle
    By alex wight in forum Generic Chinese Spindles
    Last Post: 21-09-2012, 08:57 PM
