Thread: PCB enclosure ?
    Hi All
    I have just ordered my Stepper Drivers, Breakout board & P.S.U. I now need to house them. Can anyone recommend were to buy cases or enclosures to mount this equipment in, or any other mounting ideas.
    Regards
    Ray
    You could try your local electrical wholesaler. They should be able to supply an enclosure easily.
    Ian
  3. The Following User Says Thank You to Web Goblin For This Useful Post:
  4. Common ideas:
    Old PC case
    Wall mounted electrical cabinet (often can find used ones on ebay like here and here )
    Fabricated alumnium sheet box
  5. The Following User Says Thank You to irving2008 For This Useful Post:
  6. #4
    Here you go very very nice and good price. . Metal Enclosure IP65 500mm x 400mm x 200mm - Galvanised Steel
  8. Quote Originally Posted by JAZZCNC View Post
    Thats exactly like the one I use... but mine was 10 delivered via eBay :)
  9. The Following User Says Thank You to irving2008 For This Useful Post:
  10. #6
    Well if you get any more and they are brand new I'll take 10 off your hands.!!
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
  12. #7
    Same here...
  13. The Following User Says Thank You to Jonathan For This Useful Post:
  14. Quote Originally Posted by JAZZCNC View Post
    The links I posted before are all 99p + 16 postage... i got mine a couple of years back and the postage wasn't as high but IIRC the box was 1 (not the same seller tho). If you won all 3 auctions he lists at 1 and drove to pick them up they'd be about 17.50 each i reckon :)
  15. The Following User Says Thank You to irving2008 For This Useful Post:
  16. #9
    If that new box stays at 1 I'll dance thur streets bollock naked to pick it up. . .
  17. The Following User Says Thank You to JAZZCNC For This Useful Post:
  18. #10
    I've used one of these for mine: Fibox - Cabinet - CAB ABS 504020 G think they was about 75 at the time. Its nice, ABS, Din support, IP rated and so on.
    Cant wait to finish it, got a nice little setup to go inside.
    .Me
    .Me
  19. The Following User Says Thank You to Lee Roberts For This Useful Post:
  1. CNC 3020 Enclosure/Upgrade
    By Pointy in forum Electronic Project Building
    Last Post: 27-10-2014, 09:20 PM
  2. Help on building an enclosure
    By thomashomer1986 in forum General Electronics
    Last Post: 02-02-2014, 05:38 PM
  3. eBay: 400x600x200 enclosure 40quid
    By EddyCurrent in forum Items On eBay UK
    Last Post: 18-10-2013, 10:14 AM
  4. 19inch Rack Enclosure - interference?
    By Washout in forum General Electronics
    Last Post: 22-09-2012, 08:10 PM
  5. RFQ: Custom sized aluminium enclosure required
    By benbenrf in forum Projects, Jobs & Requests
    Last Post: 26-10-2009, 03:16 PM
