    Final finished my mill conversion
    Using original lead screws but with home made Acetal nut on the X and Y axis's
    on the “Z” I have fitted a gas strut to counter act the weight of the head but left the pressure slightly high to control the backlash in the original cast iron nut, also adjusted the bevel gear meshing to get its backlash down to a figure that can be controlled by the software.
    All axis's arefitted with 3.1nm stepper motors and timing belts; X = 1:1 Y = 1:1and Z = 2:1
    the motors are driving all axis’s at a good feed rate and also cope with fast traversing.
    The drives are set to half steps which give a resolution of 0.005 mm which is fine for my intended use.
    Have fitted limit switches to all axis and am waiting for the emergence stop to arrive from Ebay.
    All the best Steve
ID:	13794   Click image for larger version.
ID:	13795   Click image for larger version.
ID:	13796   Click image for larger version.
ID:	13797   Click image for larger version.
    How well are the home made acetal nuts working ? any backlash ? probably need a guard over that belt at the front.
    You should have kept it all in one build thread instead of starting a new one, maybe Lee can combine them ?
    Yes a guard will be fitted in time; backlash X = 0.1, Y= 0.05 and Z = 0.4 (original nut) on each axis with software backlash compensation on i recorded with a DTI repeatability of position X and Y = < 0.01 and Z = < 0.03
  1. CONVERSION: Amadeal AMA 25LV Mill to CNC
    By Sherlock Holmes in forum Conversion Build Logs
    Last Post: 07-01-2020, 11:29 AM
  2. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  3. Weiss WMD25LV (Amadeal) CNC convertion
    By StevenT in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2014, 11:39 PM
  4. CNC Fusion Kit for Warco mini mill / Amadeal XJ12-300
    By rnr107 in forum Gantry/Router Machines & Building
    Last Post: 03-07-2012, 01:18 PM
  5. X3 Vs AMD 25LV (Weiss WMD 25LV) for CNC conversion
    By sebring115 in forum Milling Machines, Builds & Conversions
    Last Post: 18-11-2011, 12:20 PM
