Page 1 of 5 123 ... LastLast
    Has anyone actually done this in the UK or found a recipe that works for small machine bases
    Mike
    I can't help thinking aggregate of the appropriate size bonded with Biresin G26 Resin (5kg) may be a way forward for DIYers.
    The resin system isn't a problem as I do composites in my day job I really cannot see a way of reading the 380 odd pages of theory on CNC zone and coming up with aggregate sizes
    so was hoping someone here might have done the deed already
    Quote Originally Posted by mike mcdermid View Post
    For economy I'm guessing the trick is to use as much aggregate as possible ensuring it is adequately embedded/wetted (IYKWIM) in the binding (resin?) material.
    Quote Originally Posted by boldford View Post
    Yes that's the general idea - I've read the thread on CNCzone and a lot of it is discussing what threshold is too much aggregate since they want to save money on epoxy.
    A lot depends on what you want to use it for. The thread on CNCzone is so long because they are trying to find a mixture capable of providing a stable accurate surface which will directly support linear guides. If you're only using it to fill gaps in a casting for damping, or if you embed pieces of metal and fasteners which can subsequently be machined then clearly the requirements aren't so strict...
    Jonothan for me its easier to mould something that is all and its what im used to working with, i have the skills to mould things and this means i can do stuff at home very easily rather than pay for it machining or casting ,its as easy to mould and epoxy into place as it is to machine metal to thousandths, I suppose it depends on your background I know we have had cast bases supplied before and its purely position and glue that gets the tolerances
    That was my worry they are being tight on the resin volume.Jonothan did you gleen anything on the start point for sizes you could quickly post up I have read that many combinations on there?
    I do know the companies that pour this its done with technology (equipment) not dissimilar to laying concrete foundations I have seen it done and it is a lot wetter than anything aproaching the 10 percent figures I have seen touted towards the end of the thread, The rails (precision rails) were mounted on grout which was similar to moglice but with ceramic spheres in it and it did indeed look like grout till it glossed over,this glossing seems to indicate far more resin richness as the heavy particulates sink
    Im assuming its coming down to a scaling factor some of the aggregates they put in the grinding bases of the carbon machines we design are up to 25 odd mm I'm thinking the smaller the machine base you scale accordingly with a wall shickness ratio
    I might just have a go this weekend
    Ok an update
    DO IT IT IS EASY
    if you want to read through 400 pages of guessing suggesting and theorizing go follow the cnc zone "experts"
    I recently visited 2 companies who manufacture epoxy granite machine bases and actually are "experts" One manufactures CMMs the other very LARGE gantry mills made from Carbon fibre basically it is rocks in resin the guys gave me the full tech spec right down to the epoxy resin system which comes from HUNTSMAN ,nothing fancy rare special about it ,the rocks are quartz ,as guessed scaled to fit the section that is to be filled nothing fancy no fillers of spheroidal this that or the other ,just different sized grains and some fibres
    there is nothing clever about it fill a mould and vibrate it
    no flaming off with torches to burst bubbles etc analyzing sizes to the nth degree the applications engineer even pointed out how complicated lots of folks think this is ,cost to cast a machine 1000 a ton which was still cheaper than cast iron for a hobby sized machine your talking 100 quid
  8. The Following 2 Users Say Thank You to mike mcdermid For This Useful Post:
  9. #8
    Ok an update
    DO IT IT IS EASY
    That's really interesting. Like much "technology" there's always those that want to make it seem like Black Magic.
    Then an honest broker comes along and all the hype disappears.
  10. #9
    Ok an update
    DO IT IT IS EASY
    Mike this is something I have been thinking about having a go at now for quite a while but not had the time to chase down the final ratio of the mixture. If you can help with your experience and suppliers of the best resin to use etc I for one would be most grateful.
    Andy
  11. #10
    Quote Originally Posted by audioandy View Post
    Andy
    Me too.!! . . . Yes please Sir.!! . . . (Would also mean Andy and I could play in the slap dab together. . lol)
  1. How flat is a granite worktop?
    Last Post: 02-06-2021, 03:42 PM
  2. Self levelling epoxy resin
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 21-11-2020, 01:47 AM
  3. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
  4. HELP! Problem drilling 2.39 dia hole in Ali casting
    By woolley2002 in forum Machine Discussion
    Last Post: 04-09-2013, 09:06 AM
  5. Casting foundry around the midlands!
    By AdCNC in forum General Discussion
    Last Post: 17-05-2011, 12:04 AM
