    Hey all, I may be selling my machine and building a bigger and better one,
    one thought though, after using the chinese BK / BF blocks is that they're crap and the mounting holes are worse.
    what does a BK block comprise of?
    is it just and alu block, with a bearing pressed in and then a four screw cover to clamp it down?
    has anyone made one before? if so was it difficult? As I can chuck it on my current CNC and make some parts for it :)
    also, do I want an angular contact bearing or a double row bearing?
    Thanks!
    I will never use BK/BF blocks on my machine - yes they can work but they need a varying amount of TLC so I prefer to just make my own as then I know it will be accurate and can make it a better shape to fit the available space.
    The BK blocks are just mild steel, but it's easier to machine aluminium so I use that. You need to bore the block to the width of two angular contact bearings, put a cover on the front to press on the outer ring of the bearings to retain them and if they're single row cheap bearings you'll need a shim between them. There are plenty of examples of bearing arrangements elsewhere on this forum / CNCzone.
  1. New Gantry Ideas
    By Tomnewry in forum Gantry/Router Machines & Building
    Last Post: 05-02-2014, 09:00 PM
  2. BUILD LOG: 5'x3' Ideas and build.
    By Wal in forum DIY Router Build Logs
    Last Post: 29-12-2012, 01:03 AM
  3. Need some ideas
    By jpcnc in forum Machine Discussion
    Last Post: 29-01-2011, 06:56 PM
  4. your ideas on a pipe profiling machine
    Last Post: 03-11-2010, 04:09 PM
  5. Any ideas on the best use of this????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 01-08-2010, 10:41 AM
