Thread: rep power ???
    TrickyCNC's Avatar
    Location unknown. TrickyCNC Last Activity: Has a total post count of n/a. Referred 6596 members to the community.
    when I post, I have some stats in the top right of my post window.... join date, number of posts etc ... what is "Rep Power" ?
  2. 'Reputation'
    TrickyCNC's Avatar
    so what does it mean ? how does it work ?
    TrickyCNC's Avatar
    BTW Irving, I see you have some 'old' lathes in your sig.
    I have an old Patrick lathe from around the same period. Not had much chance to play with it much, and never used a metal lathe before, but I managed to use it to machine the end of my allthread for my Z screw :)
    I'll get a couple of quick photo's if you are interested ?
    Rich
    TrickyCNC's Avatar
    found one
  6. I did thread on restoring one of the lathes, I had to pour new bearings...
    http://www.mycncuk.com/forums/lathe-...mac-lathe.html
    TrickyCNC's Avatar
    just had a quick look . Looks interesting. I'll have a proper read when I get a chance :)
    User Reputation This section contains many settings that dictate how users of your forum are able to affect each other's reputation score.
    • Enable User Reputation system
      This is the global switch for the reputation system. If you disable this, users will not be able to rate each other nor will their scores be visible.
    • Default Reputation
      This is the reputation score that new users will start out with.
    • Number of Reputation Levels to Display
      When a user enters their User CP, they will see a list of their most recent reputation ratings. This affects how many of the latest ratings to display.
    • Administrator's Reputation Power
      If you wish to have administrator's wield a certain reputation power independent of their calculated score, enter it here. Otherwise, set this to 0 and they will use the same calculations as everyone else.
    • Register Date Factor
      The number of reputation points that a user is able to give or take is dependant on several factors, with the length they have been registered as one of them. A user's power is first initialized at 1 and then this factor and the factors that follow are used to increase it. For example if you set this to 365, every 365 days that the user has been a member of your forum, they would gain one point. So if they have been a member for five years, they would gain 5 points of power for a total of 6.
    • Post Count Factor
      The amount of posts that a user has can also affect their reputation power. Set this to number of posts that you want to award one point for. For example, set this to 50 and for a user with 500 posts, they would gain 10 points of power.
    • Reputation Point Factor
      The users current reputation score can also affect their reputation power. Set this to 100 and a user with a reputation of 1000 would gain 10 points of reputation power. If you set any of the power factors to 0, that will effectively remove that factor from having an effect on the user's reputation power.
    • Minimum Post Count
      If the reputation system is enabled, anyone will be able to rate a post but only users with a post count above the level you set here will be able to actually give points or take points from another user.
    • Minimum Reputation Count
      As with the post count above, a user must have a reputation above this level to be able to give or take points from another user's score.
    • Daily Reputation Clicks Limit
      This sets how many unique members that a forum user will be able to rate in any 24 hour period. Administrators can rate as many people as they wish.
    • Reputation User Spread
      This setting dictates how many unique members that a user must rate before they are able to rate the same member twice. The goal of this setting is to stop a member from either artificially bumping or dropping a user by repeatedly rating their posts.
    Little info on it there, its active but i've never really implemented it, so should be on the vB defaults :).
    .Me
    TrickyCNC's Avatar
    Ahh .. that's cleared it right up then ??? ! LOL
    I wondered how I got any points, as I thought everyone hated me for using MDF :D
    :) Bring on the wood
    I think while wood based machines have their limitations, they are still capable and more than good enough for some people/purpose.
    .Me
    .Me
  1. motor power and chinese spindles power HELP
    By DigiSoft in forum Spindles & Drive Motors
    Last Post: 16-09-2013, 11:17 PM
  2. Power Supplies
    By GTJim in forum General Electronics
    Last Post: 26-04-2013, 03:06 PM
  3. Replies: 0
    Last Post: 25-01-2012, 08:29 PM
  4. FOR SALE: Power supplies
    Last Post: 21-05-2011, 06:37 PM
  5. i need more power LOL
    By Scott in forum General Electronics
    Last Post: 12-04-2010, 01:41 PM
