    I'm looking at the pdf's but cant seem to discover the spacing for the holes bolting through from the top. I can see the pitch is 46mm in one axis, but in the other i cant cleary work out what the sizes are, pitch, from which edge etc.
    Thanks for any help offered.
    If you have a look here : http://www.zappautomation.co.uk/pdf/...tor-mounts.pdf you can scroll through the info pdf and find the dimensions for the BK12
    perfect, thanks webgoblin. The pdf i had wasnt as clear as this.
  1. WANTED: BK12 Bearing Block Wanted - 1 off
    By EddyCurrent in forum Items Wanted
    Last Post: 11-03-2017, 07:52 PM
  2. BK12 end float?
    By birchy in forum Lead Screws, Nuts & Supports
    Last Post: 20-07-2013, 01:28 AM
  3. Bearing Spacing on Y-Gantry-Carriage
    By WandrinAndy in forum Gantry/Router Machines & Building
    Last Post: 29-10-2012, 12:16 AM
  4. Dimensions and Weight of Denford Starmill PC Please
    By cristec in forum Milling Machines, Builds & Conversions
    Last Post: 13-08-2012, 06:02 AM
  5. BK12 & BF12 bearings
    By mlmSolutions in forum Lead Screws, Nuts & Supports
    Last Post: 04-01-2011, 10:16 AM
