Page 1 of 3 123 LastLast
    D.C.'s Avatar
    I know I said I would do a cheap mdf machine, but the more I look at it the more I trouble I have. I don't think mdf will give me a decent 3x4 cutting area for doing useful work on and at the same time be able to mill new bits for itself reliably. The amount of mdf needed for a strong structure of that size would also end up as scrap when I came to upgrade. I realised that I don't have a problem with building boxes out of wood or steel I have a problem with all the cnc fetish talk of whipping, backlash, ballscrews and the unhealthy obsession with industrial strength vibration.
    So steel it is for the frame and gantry.
    I am intending to use 80x40x4mm box for the legs and the top of the longest axis held together with plates and M8 threaded rod. For the rest of the frame I'll use 30x30x3mm box. I'll be sheathing it in mdf so that I can use the underneath as a cabinet.
    My longest axis will be 1.5m of rail and the gantry will 1.25m of rail. I am intending to construct the gantry out 30x30x3mm box backed by 3/4 inch mdf and also use 3/4 mdf for the gantry base & z-axis plates etc. Later I plan to machine new plates from 20mm aluminium to replace the mdf.
    I'll be using sbr20 supported rail for all the rails and 20mm antibacklash ballscrews/couplers driven by nema 23 3.1nm motors driven by a cw8060 with a 600w 48V 12A power supply.
    Each side of the longest axis will have a single sbr20 rail mounted directly to the 80x40 and ballscrew above, the gantry and z axis will have 2 rails and one central screw. I'll be ordering an extra long z axis but not using the full amount until I install the 4th axis.
    The steppers etc I plan to get from cnc4you and the shiny metal bits & connectors from Chai.
    Now for the questions...
    1- Is 80x40x4mm & 30x30xmm mild steel good enough for the frame and gantry and will the threads/plates hold up ok without welding?
    2- Will steel & mdf provide enough stiffness without cross bracing? (the frame will have a cabinet floor of 30x30x3mm near it's base)
    3- Will the sbr20 mount ok directly to the 80x40x4mm or do I need a cunning plan to attach it?
    4- Should I drive the two threads with a belt system or just slave an extra motor?
    5- Anything horribly flawed with this masterplan?
    I need this build to deal with light use, 3D carving of upto 4 inches of laminated ply/mdf, accurate cutting of inlays on veneered wood, occasional soft metal upto 20mm thick (only need that thickness for cutting new machine parts for it) and cutting/engraving on acrylic/pcbs.
    Thanks for all the help!
    D.C.'s Avatar
    Oh, and one last question does Chai sell the water cooled spindles?
    Quote Originally Posted by D.C. View Post
    yes, inverters too. no mounts though :(
    1) Depends how you use it, but I'd reccomend using something larger than 30x30 for the gantry - don't worry about the weight. It's easier to mount the SBR20 rails on something that is at least as wide as the rail base.
    2) MDF wouldn't be my first choice, but it will still add stiffness.
    3) Yes it will be fine on the 80mm surface.
    4) 6 of one... could spend forever discussing this. I'd probably go for two motors, Jazz will say one motor and a long belt. Price wise there's not that much in it.
    5) Use 16mm diameter, 10mm pitch (RM1610) ballscrews, not 20mm diameter. You wont gain anything by using the larger size ballscrew since those motors, especially when run from only 48V, will not be able to get good accelleration and speed with the larger ballscrew, especially if you're thinking of the RM2005 from Chai. Get RM1610. Yes the critical speed is lower, but that's only an issue on the 1.5m ballscrew and even so if comparing to 5mm pitch screws it will still go much faster as the rpm is halved for a given feedrate. For the Z-axis the best option is RM1605. Also you should use timing belts/pulleys to get the best performance...couplings are notorious for snapping or being annoying to align, whereas belts are trivial to align, allow you to change the ratio to gain speed or resolution and also help suppress resonance.
    Yes, but he's one of the more expensive sellers for spindles on eBay. I got mine from solar.jean on eBay, and know a fair few other people who have and it's been excellent.
    Quote Originally Posted by Hobgoblin View Post
    no mounts though :(
Name:	DSC08894 (Medium).JPG
ID:	7119Click image for larger version.
Name:	DSC09346 (Medium).JPG
ID:	7116Click image for larger version.
Name:	DSC08949 (Medium).JPG
ID:	7117Click image for larger version.
Name:	DSC08947 (Medium).JPG
ID:	7118Click image for larger version.
Name:	DSC08319 (Medium).JPG
ID:	7115Click image for larger version.
ID:	7112Click image for larger version.
Name:	DSC08268 (Medium).JPG
    Are they from chai jonathan? As when I asked him last week if he could supply he said no :(
    Sees spindle/motor mounts and wants ;-)
    If you're selling those Jonathan and can take paypal, don't be shy and send me a PM (2.2Kw water cooled spindle 80mm dia attaching to a 160mm wide Z plate BTW) :-)
    I'm guessing thise mounts are from Jonathan DC
    Yes they're all ones I've made. I need to make one for someone else on the forum asap, but I'm very short for time currently since I'm at university and have another project that needs finishing. However if I can make a few to the same design that would be pretty efficient...the one in the second photo from the left is easiest if made from 1/2" thick aluminium, to this drawing (can change the hole spacing if required):
    D.C.'s Avatar
    Thanks for all the help 80x40 it is then and I'll plan for using belts.
    As far as the ballscrews go, would a 20mm 5mm lead not offer better accuracy, I'm not intending to do large volume runs of stuff so speed isn't that important (as long as it doesn't case any material problems) but precision for engraving is.
    And last two questions, is there a good online resource for explaining the basic maths and mechanics for working this stuff out properly so I can stop vaguely throwing combinations of parts around in the hope that someone will work it out for me? :)
    Is there a good all-in-one type book (real dead tree type) that covers all the basic aspects of cnc preferably with emc2 examples?
    Ta very much!
  10. I have a book called "the CNC cookbook" which is very simple but a good intro. Available on amazon...
  11. The Following User Says Thank You to JoeHarris For This Useful Post:
  1. RFQ: Daft Punk Build
    By FIREWIRE in forum Projects, Jobs & Requests
    Last Post: 19-04-2013, 02:34 AM
  2. Spindle Stop?
    By manofgresley in forum Spindles & Drive Motors
    Last Post: 08-01-2013, 06:37 PM
  3. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  4. A daft question about vibration damping
    Last Post: 11-10-2012, 09:57 AM
  5. NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
    By m0nk3hjam in forum New Member Introductions
    Last Post: 17-08-2010, 02:32 AM
