12-10-2012 #10
Yes, but overall you're still better off getting 10mm pitch ballscrews since you can use pulleys and have a 1:2 (motor:ballscrew) ratio to get the same resolution as a 5mm pitch screw on 1:1. If you got 5mm pitch then the ballscrew has to spin twice as fast, so unless the critical speed is twice as great you will be limited. The critical speed is just proportional to the diameter, so using 20mm will only gain 25% speed hence there's no point. If the 20mm diameter screw was 10mm pitch I probably still wouldn't use it since the required torque to accelerate it is much greater.
Also the resolution you get from 5mm pitch is hardly ever required. I cut this with (roughly) 10mm effective pitch:
The area shown in that image is roughly 50mm wide...
Er, me? But seriously, the information on this forum is all you need. If you've not already then read as many of the build logs as you can as the same things come up regularly, so it shouldn't take long to find out what the best way to each part is. The fact you're intending to use LinuxCNC doesn't make a lot of difference to the process - in most cases it'll be just selecting a different option when you export the G-code from the CAM program.
The Following User Says Thank You to Jonathan For This Useful Post:
RFQ: Daft Punk Build
By FIREWIRE in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-04-2013, 02:34 AM -
Spindle Stop?
By manofgresley in forum Spindles & Drive MotorsReplies: 21Last Post: 08-01-2013, 06:37 PM -
E-STOP Circuit - will this cause any problems?
By birchy in forum General ElectronicsReplies: 34Last Post: 18-12-2012, 04:35 AM -
A daft question about vibration damping
By D.C. in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 11-10-2012, 09:57 AM -
NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
By m0nk3hjam in forum New Member IntroductionsReplies: 6Last Post: 17-08-2010, 02:32 AM
