    D.C.'s Avatar
    Lives in Birmingham, United Kingdom. Last Activity: 05-01-2016 Has been a member for 4-5 years. Has a total post count of 326. Received thanks 31 times, giving thanks to others 24 times.
    While perusing the internet I came across this interesting chap:
    Digital Caliper Pinouts - Robot Room
    The modules he is using are pretty cheap, $8.95 from the US:
    Digital Caliper With Data Output Port
    I was planning on using either hall effect or inductive proximity sensors wired into an arduino for limit switches so I will have enough ports available to put 3 of these bad boys
    Would it be possible to use 3 of these digital caliper modules to provide absolute position feedback on a CNC router at low cost I'm not sure if a cnc machine's rapid movement would prove to violent for calipers to measure accurately to their usual precision, any thoughts?
  2. have a search. Both Robin and I have built DRO using digital calipers. the read rate is far too slow for use as an active feedback of position, realistically with settling time its half a second or more. fine for the manual mill though.
    mind you, these would be worth buying to get the cable, as those are like hens teeth and cost more than that on their own!
    D.C.'s Avatar
    I ordered one because I needed one anyway, did you use the nerdkit setup for the mill?
    NerdKits - Digital Calipers DRO
  4. No, I designed, built and programmed my own.
    http://www.mycncuk.com/forums/genera...-idea-dro.html
    D.C.'s Avatar
    That is a good thread thanks, have to file it away for future reference. :)
  1. Feedback poll - which age group are you?
    By mocha in forum General Discussion
    Last Post: 1 Week Ago, 10:47 AM
  2. Doris CNC - early feedback appreciated
    By woodspiral in forum Gantry/Router Machines & Building
    Last Post: 08-06-2014, 09:57 AM
  3. Feedback
    By Jester in forum Stepper & Servo Motors
    Last Post: 02-02-2014, 02:49 PM
  4. Feedback Poll - Do you like reciving the Newsletter ?
    By Lee Roberts in forum General Discussion
    Last Post: 24-12-2012, 05:34 PM
  5. router jumping position
    By johngoodrich in forum Linear & Rotary Motion
    Last Post: 23-09-2011, 05:31 PM
