Thread: Hi from Reading
    I'm in the process of buying a Microcarve MV3, with planet-cnc driver.
    The intention is to start making parts for 1/6th scale tanks.
    I hope to end up machining aluminium but I guess it would be best to start with something softer...
    Adrian.
    Hi Adrian, firstly welcome to the forum :) secondly congrats on getting into the world if CNC...
    Neil...
    Build log...here
    Thanks Neil
    Quote Originally Posted by Saracen View Post
    Adrian.
    Welcome to the forum Adrian, best of luck with your new machine but from what I have learnt in a short time on here I doubt you will be cutting much aluminium with it. Have a look at the build logs & it will give you a better idea of what you need if you want to machine ally.
    I'm aware of the limitations of cutting aluminium and have had some conversations with John@Microcarve about it. He seemed to think the MV3 would do it but only if the spindle was up to it and the speed and cut depth were minimal. He recommended a Bosch router but the particular model doesn't seem to appear much over here.
    Speed isn't an issue for me and budget is, so after 12 months of prevaricating I decided to jump in and at least get something on the bench which would cut shapes for me. Whether it'll do the job to my satisfaction is another facet of the learning curve
    Adrian
  1. NEW MEMBER: New Member from UK near Reading
    By picyman in forum New Member Introductions
    Last Post: 16-02-2014, 10:37 PM
  2. NEW MEMBER: Newbie in reading
    By Mougli in forum New Member Introductions
    Last Post: 03-02-2013, 04:30 PM
  3. NEW MEMBER: New member from Reading
    By madd in forum New Member Introductions
    Last Post: 04-12-2010, 12:33 PM
  4. Reading and fixing Chinese scales
    By irving2008 in forum Tool & Tooling Technology
    Last Post: 24-02-2010, 09:35 PM
  5. Any old Draftsmen reading this?
    By BillTodd in forum Milling Machines, Builds & Conversions
    Last Post: 18-12-2009, 10:14 PM
