    What would it realistically cost to have a press made that could make headphone cups ? I was thinking of making some indestructible headphones , I was discussing with my gaming friends and they would be will to pay £200 plus for a set of headphone that where modular and great sounding but would basically last a life time, the only thing when I did my pen on paper drawing I couldn’t really make is the cups for the phones. Could I make a press for ally cups or would I need a cast iron press ? What would it cost to get one made ?
    Ralph Waldo Emerson
    Is a flypress sufficient? Could you instead machine the cups out of a block/bar on a mill/lathe? If you're not making many that may work out cheaper...
    Cheapest and easiest way I'd have thought would be to make the cups by spinning them. If you're looking at thin Ali then should be possible with DIY tools adapted?
    Neil...
    Build log...here
    Do you have a rough design of the cups, we can see? I don't know what you mean by modular (showing my thickness).
    I dont know what i flypress is Jonathan but a quick look on google and yes that would be ideal , its only 3mm ali. I thought of milling one out of steel and then pressing the Ali into it. If they turn out to be good and I can make a profit hopefully i can sell some more :)
    Yes I had thought of making some circular cups ( would be really retro) as well, maybe cheaper, not sure though I'm looking for the path of least resitance atm lol
    Quote Originally Posted by oscar View Post
    Just hollow earphone cups , I must have 5 pairs in a box jointly costing £300 broken, I suppose I could try and fix them but thats not my point. oscar modular is when you can break it down into smaller pieces and replace the piece easily .. really with standard equipment, say for instance the jack and cable, if you break it normally its hard wired into the earphone, but if it is designed with a Jack at each end and socket on the earphones you can simply buy an off the shelf lead and your back to normal. You can also go from standard earphone plug to RCA if you want, same thing if you have a microphone.
    Ralph Waldo Emerson
  6. Well if u were after someone to machine u a steel mould (or anything for that matter) then drop me a pm ;-)
    Quote Originally Posted by AdCNC View Post
    Thanks for the offer :) , I think my CNC night be able to do it , not sure but I can do some tests.
    Ralph Waldo Emerson
    indestructable headphones... bayerdynamic dt150
    i used to use them when i did sessions as a drummer, absolutely legendary headphones and they are completely repairable and cost about 120 odd quid new
    beyerdynamic DT 150 - Studio Headphones - Studio & Stage - Headphones & Headsets - Headphones & Headsets
    D.C.'s Avatar
    Lives in Birmingham, United Kingdom. Last Activity: 05-01-2016 Has been a member for 4-5 years. Has a total post count of 326. Received thanks 31 times, giving thanks to others 24 times.
    It is the 21st century, no self respecting pair of headphones comes without el wire.
    LEVEL HEADED - EL WIRE HEADPHONES
  1. WANTED: Drill press
    By D-man in forum Items Wanted
    Last Post: 30-08-2013, 06:45 AM
  2. Plasma, guillotine and press parts available, specialising in low volume
    By matttargett4 in forum Opportunities Available & Sought
    Last Post: 03-01-2013, 12:04 PM
  3. Bearing interference fit / press fit
    By Mad Professor in forum General Discussion
    Last Post: 30-09-2012, 10:26 PM
  4. RFQ: small, primitive Press with cutting and bending capability
    By Noel.C in forum Projects, Jobs & Requests
    Last Post: 29-05-2012, 10:37 PM
