Thread: 7' X 4' Combi
03-04-2013 #101
Sorry Rick, I thought you were a bit further down the line than that. I had not realized you still had so much to do, but at the speed your'e going at it won't be long now. G.
16-04-2013 #102
Well there is a lesson learned!!.
Today I fitted the drag chain, and spent two hours drilling, and routing the cables through the frame back to the control box, Oh how neat it was, i fitted three bright new NPN-NO-6-36v proximity sensors to the X- Axis....LOL oh what fun that was.
Evertime i powered up the driver a sensor triggered, I didnt know what was going on.
I had used some 5 core cable for the steppers leaving 1 spare wire in each cable for the sensor, I had already run some wire up to the gantry for the sensor supply..
So now that i know i will have to use Screened cables on the machine so i dont get all these stray signals.
Can anyone suggest a four core screened cable that wont rip my arm off please, as i will wire the whole machine with what ever i get.
The drivers are 2MA860H Peak 7.2A AC50V-80V DC36V-110V running at 72VAC driving 4NM NEMA 24 Motors
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
16-04-2013 #103
Here you go. CY Cable 4 Core
Don't run power cables along side signal cables.! Even shielded cables else your asking for trouble.
16-04-2013 #104
16-04-2013 #105
Dean,
Is that 4 core 4 numbered cores plus earth or 3cores and earth ?John S -
17-04-2013 #106
4core = 3 numbered + Earth Need eyes like super man thou to see numbers not very good in that regards but it's cheap enough and Ok quality.
Carefully. . .Lol . . . They will be ok in same Cable chain if not too tight Just don't fasten them together with cable ties/tape or owt daft like that.!!
17-04-2013 #107
17-04-2013 #108
Yes anything that gives some separation will work. The better cable chains like Igus can be bought with dividers that can be inserted.
With higher Power cables like from VFD I run bit of silicone tube between, often it's water pipes, but anything that can keep a bit of separation really.
I find those that have the most troubles with noise are the neat freaks that need everything tied and bound together with cable ties or tape.!!
Ric What voltage are you powering the Prox sensors with.? . . . . Running 24V on signal cables makes a big difference to noise handling has well.!! Often folks use 5V for Limits etc signal cables and get noise, esp if they haven't been too careful with ground or cable routing.!
17-04-2013 #109
Well, whilst sorting out what ports to use and testing them i used 5V (just to keep things simple and at the right voltages for the board)but they wernt on the machine, it wasnt untill i did all the fiddly threading of the wires through the frame and the cable chain that i got problems, i then tried it on 12v as that is what i wanted to use anyhow, but still hadnt decided how to bring that back down to 5v for the bob.
