Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by WandrinAndy View Post
    I may even go with the USB-CNC software+hardware instead of Mach3+ESS+Bob if I've understood things correctly.
    Just be careful with the naming/packages ....the program I was speaking of earlier is called CNC-USB, rather confusingly I believe there's also a product out there called USB-CNC...I know zilch about it.
  2. The Following User Says Thank You to HankMcSpank For This Useful Post:
  3. #22
    D.C.'s Avatar
    For people that have an open source fetish or are broke and don't want to pay for software there is a good tutorial here for an all free workflow. It's worth pointing out that most of this software will also work just fine on windows (gimp, inkscape, pycam) I'm not 100% sure but I don't think EMC2 will work on windows at all.
    Open Source CNC Toolpathing Workflow
  4. #23
    The only drawing program I have ever used was the free version of SKETCHUP some time ago and I could easily use that to design my machine.
    Or I could use the design exercise as an opportunity to get accustomed with more of a proper CAD program that could also be used to design parts for the machining workflow after the build.
    Based on what I have learnt on this forum, I am currently favouring VIACAD 2D 3D V8 which at less than $100 USD looks like decent value-for-money for me as a hobbyist with very limited budget, so I have just downloaded the 14-day free trial.
    Does anybody on the forum have good or bad views of VIACAD 2D 3D V8 please ?
    Thanks, Andy
  5. #24
    Just a quick heads-up for anyone that uses Sketchucam, a new version was released last month which has quite a few updates and new features. It looks like you need to register to download it now, but it is a 'free' solution for simple gcode generation from within Sketchup.
    There is also another plugin for Sketchup in development at the moment for use with 3,4 and 6 axis machines which is getting close to completion : Sketchup Plugins for use in Aircraft Design | FoamCasualty
    Si.
  1. Mach3 / cambam
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 01-04-2013, 06:02 PM
  2. Cambam / milling Alu
    By dudz in forum CAD & CAM Software
    Last Post: 23-12-2012, 05:22 PM
  3. Drilling Acrylic with CamBam
    By m.marino in forum Machine Discussion
    Last Post: 06-06-2012, 04:45 PM
  4. How do i make this in cambam?
    By motoxy in forum CAD & CAM Software
    Last Post: 09-02-2012, 06:01 PM
  5. RFQ: Parts for my hobby from your hobby
    By Phobia1 in forum Projects, Jobs & Requests
    Last Post: 18-01-2011, 02:57 PM
