Page 3 of 8 FirstFirst 12345 ... LastLast
  1. #21
    First part!
    Went fairly conservative on speeds as this was my first part. Around 3m/min and 5mm DOC
  2. #22
    Levelling the bed. Profile is done at 6.5m/min with 5mm DOC and the pocket for the bed levelling was 9m/min at around 1-2mm DOC. Took longer to hover the mess than it did to run the job!
  3. #23
    Whats that big fooookin clear tube thing hanging down the side for then.?????. . . Strap the bugger to spindle and turn it on.!!
  4. #24
    It was clean for months. It needs to get dirty lol
    A dust shoe is on the to do list but just like you said, now its done I can't be arsed and want to get stuck in cutting some of the things I've got designed and waiting. Glad I did all the tidying, probes and prettiness before plugging it in!
  5. #25
    Quote Originally Posted by Shinobiwan View Post
    Yep happens every time.!! . . . Soon has them steppers turn and spindle fires up all the plans turn to shit.!
  6. #26
    For once someone surfacing the bed at a respectable feedrate :)
    What stepover did you use? When surfacing MDF, if I require an especially good finish, for instance when machining a PCB, I surface the bed with a 40% stepover parallel to Y (since Y is the fastest axis) and if not I use around 70%
    I know the feeling. I did make something to collect the dust initially, but it didn't work very well and I never got round to improving it...
  7. #27
    90% there as its not critical. I'm only laying 4x4ft sheets over the bed.
    Still got an ok finish even with the haste.
  8. #28
    lol, cant wait for that day to come myself
    .Me
  9. #29
    More fun today.
    And the result:
  10. #30
    What is the grey material?
  1. Bridgeport Retrofit motion control?
    By drumsticksplinter in forum Milling Machines, Builds & Conversions
    Last Post: 28-03-2015, 11:00 PM
  2. Conect 121 Retrofit
    By Sooty in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 17-02-2015, 11:45 PM
  3. VFD retrofit Hobbymat BFE65
    By manofgresley in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 05:07 PM
  4. Boxford 125 CNC retrofit advice
    By pneanvil in forum Boxford Lathes
    Last Post: 05-12-2012, 11:47 PM
  5. Motor size 23' and 2/1 reduction for Z axe on SX3 retrofit.
    By A2P in forum Linear & Rotary Motion
    Last Post: 15-09-2010, 05:14 PM
