Page 1 of 6 123 ... LastLast
    Hey guys,
    After buying shite from Strike CNC, I've spent the last year fixing it along with a bit of upgrading to cheer myself up too! Starting this thread to just give myself a bit of motivation and something to look forward to as its nearly complete and should be cutting very soon.
    Here's the original turd I got from the anus at Strike. And yep I know, millions of problems and only just up to the task of cutting air (bit of an exaggeration but its not far off the truth)
Name:	Strike Original (1).JPG
ID:	7686 Click image for larger version.
Name:	Strike Original (2).JPG
ID:	7687 Click image for larger version.
Name:	Strike Original (3).JPG
ID:	7688 Click image for larger version.
Name:	Strike Original (4).JPG
    After the first disaster the main area of concern was the gantry and Z axis. So back off to Strike and flushed some more money down the toilet to have them 'upgraded'. Threw out the Kress spindle and got one of the 2.2kw chinese WC ones whilst I was at it.
    Here's the new gantry. Much better than the last with 200x40 extrusion. Happy with that.
Name:	New Gantry (2).jpg
ID:	7693 Click image for larger version.
Name:	New Gantry (1).jpg
    It wasn't all good news though because Strike, true to form, botched the new Z axis. Might look fine on these shots but you couldn't correctly tighten the supported rails due to mickey mouse engineering - result = play at the cutter.
Name:	Strike 2nd Z Attempt (2).jpg
ID:	7695 Click image for larger version.
Name:	Strike 2nd Z Attempt (1).jpg
    So off comes the Z axis and I have a new front plate made to try solve the problem of not being able to tighten the supported rail. This works fine but then I realise despite ordering a machine with 200mm of Z travel I only really have about 175mm. Making it very tight for some of the jobs I have in mind. Thanks for that Strike. So I think sod it, I'll design my own. Can't be that hard can it.
    Here's the result...
Name:	New Z Axis (1).jpg
ID:	7696 Click image for larger version.
Name:	New Z Axis (2).jpg
ID:	7697 Click image for larger version.
Name:	New Z Axis (3).jpg
    Bit over engineered for the machine with 25mm linear rails and a 25mm thick ecocast front plate but overkill never hurts. It does slow you down though so will no doubt have to dial the speeds/acceleration back a tad after this but I'd rather do that and have accuracy with a good finish.
    And on the machine:
Name:	New Z Axis (4).jpg
ID:	7699 Click image for larger version.
Name:	New Z Axis (5).jpg
ID:	7700 Click image for larger version.
Name:	New Z Axis (6).jpg
    Looks good so far, happy with that. You can also spot the X and Y ballscrews in those shots. These now have the correct ballscrews mounts with angular contact bearings instead of the Strike's cheap substitute - round rail supports with captured regular chinese ballrace bearings. Those will slop about like crazy with a bit of wear on them. Strike may now be out of business but Merchant Dice use the same method in some of their machines so watch out for that.
    The electronics, whilst functional in the original Strike machine, weren't giving me the speeds I'd have liked. These were upgraded for better Leadshine AM882 drives along with higher volts (75v). What wasn't acceptable was the dangerous wiring job by Strike. Things like the 240v wired through the e-stop, bare wire hanging out of screw contacts, broken wire insulation exposing dangerous DC voltages, no cabinet ground and incorrect colour coding on wiring. It was a death trap basically and would never have passed any sort of safety test.
    So I ripped the lot out and started from scratch with standard and sound safety practices such as e-stop on relays, home/limit switches, star grounding, cable management etc.
    Strike's attempt:
Name:	Control Box Original.JPG
    After the upgrade:
Name:	Control Box New.JPG
    I upgraded all the stepper wiring to shielded whilst I was at it too. Nothing more annoying than RF and EMI noise problems and the WC spindle can give off a fair bit of that.
    Couple of simple convenience mods. LCD on an swivel arm so I can see Mach wherever I am.
Name:	LCD Arm 02.JPG
ID:	7707 Click image for larger version.
Name:	LCD Arm 01.JPG
    And to the rear of the dust enclosure Strike supplied the machine incomplet! The doors were missing at the back. The whole idea of a dust enclosure is to keep dust out the workshop... missing doors isn't going to help that. I came up with something anyway but space was tight so went with folding doors.
    Not quite done yet though. I'm having a complete strip down of the bed, gantry and z axis done.
    Once finished the bed will have a lot more support, bit more bracing on the gantry and everything will be square and true. I'll be cutting after that. Woop at last!
    For once someone surfacing the bed at a respectable feedrate :)
    What stepover did you use? When surfacing MDF, if I require an especially good finish, for instance when machining a PCB, I surface the bed with a 40% stepover parallel to Y (since Y is the fastest axis) and if not I use around 70%
    Quote Originally Posted by Shinobiwan View Post
    now its done I can't be arsed and want to get stuck in cutting some of the things I've got designed and waiting
    I know the feeling. I did make something to collect the dust initially, but it didn't work very well and I never got round to improving it...
    90% there as its not critical. I'm only laying 4x4ft sheets over the bed.
    Still got an ok finish even with the haste.
    D.C.'s Avatar
    Still, a bit of tweaking is to be expected. At least the steppers were ok. ;)
    Looking at the quality of work you have done its a shame you did not build it all in the first place. Congrats on actually producing that silk purse from a strikes ear. Nice work.
    The more I know, I know, I know the less. (John Owen)
  1. Bridgeport Retrofit motion control?
    By drumsticksplinter in forum Milling Machines, Builds & Conversions
    Last Post: 28-03-2015, 11:00 PM
  2. Conect 121 Retrofit
    By Sooty in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 17-02-2015, 11:45 PM
  3. VFD retrofit Hobbymat BFE65
    By manofgresley in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 05:07 PM
  4. Boxford 125 CNC retrofit advice
    By pneanvil in forum Boxford Lathes
    Last Post: 05-12-2012, 11:47 PM
  5. Motor size 23' and 2/1 reduction for Z axe on SX3 retrofit.
    By A2P in forum Linear & Rotary Motion
    Last Post: 15-09-2010, 05:14 PM
