Page 11 of 28 FirstFirst ... 91011121321 ... LastLast
  1. #101
    Not touched the mechanical design for a while as I got distracted down the route of designing my own stepper driver...
    So here's a small update. I'm feeling quite bad for how much this is looking like one of JAZZ's machines! Believe it or not I am not trying to copy you Clive!
    I am still not happy with the way I have the Y axis plates attached to the steel box section. Think I need to come up with something better?...
  2. Believe it or not I am not trying to copy you Clive!
    If you was, I would be more than excited, but I don't see the resemblance to mine if it is me you are referring too. ..Clive
  3. #103
    Oops! I meant Dean...it's been a long day.
    Nice machine though! :)
  4. #104
    Quote Originally Posted by biketrialsdave View Post
    No problem with copying my stuff and you wouldn't go far wrong copying clives either it's an excellent machine.!
  5. Quote Originally Posted by JAZZCNC View Post
    Your so kind. But I wouldn't go that far ..Clive
  6. #106
    I think the end is nearly in sight!!
    All steel plate is currently 3mm ("Y axis "end stops" and end plate attaching bed), should I make this thicker? Will there be any problems welding it to 3mm thick box section? I have a friend who works at a laser cutting place so I'm hoping to get those pieces cut there.
  7. #107
    Any comments on the above would be appreciated =) I think I need to start looking at places to get the aluminium milled soon!
    I've been a bit distracted with designing my own stepper drivers but going to put that to the side until I have the mechanical design all done.
  8. #108
    I think it would be better to extend the Z axis rear plate to meet up with the bottom plate, like this; it's not shown on this photo but my ball nut fits on the inside of that plate.
    3mm plate is too thin I reckon, I used 10mm flat bar for brackets, maybe 6mm would do, see what others say about it.
  9. #109
    Thanks for the input Eddy!
    Well it's been a long time since my last post and since then there have been some large changes... Now, I am fully awaiting the groans and face palms when I say this....
    I have decided to return to using aluminium profile for the frame. The reasons being:
    1) My welding skills are not quite there. They aren't bad but I envisage a lot of trouble trying to get things square and aligned correctly.
    2) I now have free access to a water jet which I plan to cut beefy steel brackets from to connect the profile together with.
    3) I have re-evaluated what I will mainly be realistically cutting and steel may be OTT!
    Anyway, enough excuses. Here's the latest design. I would really like to get the ball rolling with the custom aluminium parts. Am I best posting on the job request page and going from there?
    Dave
ID:	13543   Click image for larger version.
ID:	13544   Click image for larger version.
  10. #110
  1. aluminium profile for cutting bed of router
  2. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 02:01 AM
  3. Multiple CNC Opportunities both Nationally and Internationally
    By cnc jobs in forum Opportunities Available & Sought
    Last Post: 21-09-2012, 01:01 AM
  4. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
  5. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
