Thread: M542 problems see pictures
hi guys
wee problem, was careful wiring up my M542 to my breakout broad that the mix up the + an - for the 24v supply and BOOOOM.
opened it up and this is the result
http://sphotos-f.ak.fbcdn.net/hphoto...11688174_n.jpg
i no how stupid of me.
now i open one another one and this is wat is missing
http://sphotos-e.ak.fbcdn.net/hphoto...01523726_n.jpg
can anyone tell me what it is???? the code on it is 1051 RV done a google serach but got nothing.
http://sphotos-d.ak.fbcdn.net/hphoto...86732269_n.jpg
thanks guys
07-01-2013 #2
its a surface mount 1.05kohm resistor
however i wouldnt like to say if just replacing that will make everything alright
08-01-2013 #3
08-01-2013 #4
Me also thinks it's a diode, probably there to stop you from blowing the board up with what you've managed to do (swapping voltage pos and neg). Since re/de-soldering anything from surface mounts can be a bit tricky, I'd suggest getting a replacement from somewhere (you can always contact the manufacturer to check for the model and package no) and leaving the good board in peace.
Regards,
dsc.
08-01-2013 #5
it looks like a diode to me as well, put there to short the supply if you connect it wrong. If so you should be able to run the drive without it there, have you tried it.?
08-01-2013 #6Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
08-01-2013 #7
i've replaced so many of those i've lost count, sometimes the audio chip would take a beating but i don't remember the rf output failing from that.
General electric made their cb radios with the supply connection the same as the standard uniden chasssis but with the supply reversed (that made me a fair bit of cash) especially when they were told to replace the power lead and didn't bother.
the good old days eh!Last edited by i2i; 08-01-2013 at 03:27 AM.
08-01-2013 #8
Yep you are right, they used to come in with a really quiet hiss from the speaker, the brain is letting me down.. I used to replace a lot of RF outputs on the sets that the SWR was run high and the screwdriver gang had tweaked of the end of the scale LOL... Yep the good old days... easy money too putting the extra channels in with the 10kc shift (ver-icap to 10.240) LOL yep them were the days...LOL Rick
08-01-2013 #9
if the diode was put in series with the supply and the device on one lead, it would protect it far better but there would be a small voltage drop across the diode.
08-01-2013 #10
Get off the the cybernet boards and phase lock loops you old gits and flipflop back to work before i wack your BREMI
send pictures via PM
By dazza in forum General DiscussionReplies: 1Last Post: 27-06-2013, 10:10 PM -
pictures of ballscrews??
By wilfy in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 28-10-2012, 09:09 PM -
ZP5A-INT breakout an M542 driver problems
By ciaranconlon in forum Motor Drivers & ControllersReplies: 2Last Post: 09-04-2012, 05:52 PM -
Halftone CNC Pictures
By Mad Professor in forum General DiscussionReplies: 3Last Post: 01-09-2011, 11:40 PM -
Engraving pictures
By Kai in forum Computer SoftwareReplies: 1Last Post: 19-07-2011, 09:49 PM
