    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 16 Hours Ago Has been a member for 9-10 years. Has a total post count of 281. Received thanks 2 times, giving thanks to others 70 times.
    Who sells profile "T" and "L" joining plates to brace 45x45 profiles together ? looking for 4mm thickness and around 100mmX100mm
    like these ;
    No idea where you can get them, but I made a fair few for luke11cnc here on this forum. If you're not to fussed about how it looks you could get some 4mm aluminum sheet and make some yourself, since they don't need to be particularly accurate.
Name:	DSC08288 (Medium).JPG
ID:	7847Click image for larger version.
Name:	DSC08287 (Medium).JPG
    I've unfortunately not got time to make you some, unless you can wait about a month!
    dudz's Avatar
    Ok.ta.... I will probably make some later then. It just would have been easier to buy some "off the shelf" if they were about.
  1. RFQ: Z+Y plates & motor bracket
    By Gytis in forum Projects, Jobs & Requests
    Last Post: 09-08-2013, 12:45 AM
  2. RFQ: RQF: Router Gantry plates
    By lateAtNight in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 04:56 AM
  3. RFQ: Small Alu plates needed
    By m_c in forum Projects, Jobs & Requests
    Last Post: 06-06-2012, 01:33 PM
  4. NEW MEMBER: Finally got round to joining the best CNC group on the net!!!
    By g4ghp in forum New Member Introductions
    Last Post: 19-03-2012, 07:31 PM
  5. NEW MEMBER: Hello Im interested in joining you all
    By Guisborough in forum New Member Introductions
    Last Post: 18-08-2010, 11:01 PM
