16-01-2013 #27
The press fit as bad as it may look does not concern me as much as the steppers holding ballscrew in place. The reason being is I can measure the shaft of the motor moving along the motors axis as the load on the ballscrew changes. Inside the motor is a spring washer, if you pickup a stepper and try pulling and pushing the shaft you will see it takes very little force to move it. Maybe your lathe has different types of steppers with thrust bearings built in, or maybe its designed to work within the range of the spring washer inside?
CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
FOR SALE: Marchant dice cnc router mill compatiable with mach 3
By gavztheouch in forum Items For SaleReplies: 7Last Post: 23-03-2021, 12:59 PM -
BUILD LOG: A3 Marchant Dice Kit
By neo in forum DIY Router Build LogsReplies: 25Last Post: 03-03-2021, 11:54 AM -
Marchant Dice
By agent17 in forum Marketplace DiscussionReplies: 28Last Post: 06-06-2020, 11:06 AM -
Marchant Dice on eBay
By irving2008 in forum Marketplace DiscussionReplies: 4Last Post: 06-09-2008, 05:37 PM
