Thread: Steppers, Series, Parallel
12-01-2013 #1
At the moment I'm deep in doing the Electrics for my new machine. I have read that you can have the stepper motor coils in a series or parallel arrangement.
My questions are, which is preferable and why, and how much difference does it really make, and thridly would it be a feature to put in some relays to switch between the two wiring types..
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
12-01-2013 #2
My post here explains why, but the simple answer is that in most cases parallel is the best arrangement. You get slightly greater torque at low speeds from bipolar-series, but since the difference is small you're better off using parallel it gets better torque at high speed due to the lower inductance.
There might be something to gain by switching between the two, but I doubt it's worth the trouble here especially since switching whilst the driver it turned on could damage it.
12-01-2013 #3
I assume the numbers will be reresented in a graph somewhere. As for the switching my panel is a one time sequenced progression so you can only progress to the next switch once you have made a choice on the previous one and if you make a mistake you must start again, so i would put that choice above the stepper power switch.. But it seems imaterial if there is so little difference..
12-01-2013 #4
Also how do you tell the maximum voltage to drive the motors at and is this different with the two arrangements?
12-01-2013 #5
Not that easy has the voltage requirements would change has well. Serial requires much higher voltage(roughly double parallel) also the chance of blowing the drive is great.
The switching would have to happen with the power to drives off has it's 99% sure the drives will pop.!!
Not required anyway so keep it simple.!!
12-01-2013 #6
My drives can be take upto 80-vac or 100vdc but it appears the concensus is parallel so Parallel it is then...
12-01-2013 #7
Parallel works best for me, you get faster rapids and cooler running motors.
I have blown up quite a few drivers running in series due to the back emf/motor inductance.CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
That's a surprise because I tried wiring in parallel once. Once being the operative word. I got little appreciable speed advantage and lots more heat.
Also, why is everyone worrying about Volts, our drivers already have lots of Volts? Parallel wiring requires twice the Amps.
12-01-2013 #9
But aren't your motors on mains voltage, or something silly high, in which case it's hardly surprising that they would overheat in parallel?
See the post I linked to earlier - it's because the inductance is 4 times greater when in series, so you need a higher voltage to 'overcome' that.
12-01-2013 #10
Bridgeport series 1 MDI / CNC tooling
By drumsticksplinter in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 08-03-2013, 04:47 PM -
Mitsubishi FR-D700 Series VFD
By acollins in forum Motor Drivers & ControllersReplies: 4Last Post: 31-05-2012, 07:24 AM -
FOR SALE: Microloc Series 50 Workholding System
By Bokoshoko in forum Items For SaleReplies: 0Last Post: 05-02-2012, 02:11 PM -
WANTED: Looking for a used axyz 4000 series cnc router
By flanagaj in forum Items WantedReplies: 0Last Post: 30-12-2011, 11:03 AM -
Interact series 2 speed controller problem
By fastcarl in forum Machine DiscussionReplies: 1Last Post: 25-01-2011, 09:50 PM
