Thread: Bearing Blocks
    What problems could I come across if I was to use a BK12 bearing block instead of a BK15.
    The reason I ask is that the BK12 mounting holes just about fit on the slots of the 45x90 aluminium profile. If it was only the centre height of the bearing then a spacer could be used.
    Am I missing something obvious?
    Bk15 blocks tend to be fitted to 20mm screws and BK12 to 16mm but there's really no reason why you couldn't use them.! . . . It's just not standard procedure so you'll need to specify BK12 machining if your ordering 20mm screws other wise you'll get BK15 machining.!!
  1. What is the best way to mark out for bearing blocks and linear rails?
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 18-05-2014, 01:08 PM
  2. FOR SALE: HIWIN & THK guide blocks and rails
    By vigen20 in forum Items For Sale
    Last Post: 27-02-2013, 09:37 AM
  3. Terminal blocks
    By Rogue in forum General Electronics
    Last Post: 19-09-2012, 10:01 PM
  4. FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
    By Jonathan in forum Items For Sale
    Last Post: 06-11-2011, 04:26 PM
  5. FOR SALE: 25mm round rail bearing blocks
    By D-man in forum Items For Sale
    Last Post: 31-10-2011, 08:26 AM
