Thread: Warco VM18
    PWD's Avatar
    Lives in Chester, United Kingdom. Last Activity: 26-09-2016 Has been a member for 4-5 years. Has a total post count of 20. Received thanks 1 times, giving thanks to others 1 times.
    I have a Warco VM18 mill and was wondering how hard would it be to convert to a 3 or 4 axis CNC ...or is there anybody out there who could do the work to a good spec and in reasonable time?
    http://www.warco.co.uk/milling-machi...g-machine.html
    Quote Originally Posted by PWD View Post
    How longs a piece of string ?? How easy it would be would depend mainly on your mechanical & electrical skills. Found a thread on cnczone which you may find worth a read.
    Weiss Milling Machines - CNCzone.com-The Largest Machinist Community on the net!
    Done about 3 of these now.
    One thing to be aware of whoever does it needs access to a decent sized mill as on the WM18 the bed sags in the middle underneath.
    This happens in the casting process and is no problem except that it will not clear the ballnut. Remedy is to take a skim from end to end underneath, to get the clearance. WM16's may just clear, some do, some don't. Short bed WM14's are usually OK.
    John S -
    PWD's Avatar
    Thanks for the replies and pm,s have now got something to consider ..sorry for the slow response .
  1. Warco WM16 Conversion
    Last Post: 25-03-2011, 08:32 PM
  2. Warco mini mill cnc conversion
    By buster in forum Milling Machines, Builds & Conversions
    Last Post: 20-03-2011, 06:48 PM
  3. CONVERSION: Warco Major CNC build log
    By Robin Hewitt in forum Conversion Build Logs
    Last Post: 10-12-2010, 02:14 PM
  4. NEW MEMBER: Warco super major mill
    By ste64 in forum New Member Introductions
    Last Post: 26-05-2010, 03:27 PM
  5. Warco Drawbar woes...
    Last Post: 21-12-2008, 11:56 PM
