    Tenson's Avatar
    Lives in London, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 6-7 years. Has a total post count of 529. Received thanks 28 times, giving thanks to others 8 times.
    Blimey that got my head twisted Jazz! I'll have to read the links first I think. Thanks though, I'm sure it will be helpful when I understand it.
    I don't suppose anyone knows if there is a simple button to do this in Dolphin? :)
    What exactly are you wanting to do.?
    Like someone mentioned nesting may be your easiest answer if you want simple.? Thou often nesting comes has an extra option along requiring more Cash.!!
    If for instance you just want 4 or 6 parts out of one sheet then do like John suggested and use work offsets. It's very easy to do just set your workoff sets in Mach then either copy code 4 times replacing G54 in each with a new offset. Or better still just put the code in subroutine then after each return put the new work offset.
    Something like this but you'll after set the work offsets in Mach's offset list first.
    G21 G40 G49 G54 G80 G90 G91.1
    m98 p1000
    g55
    m98 p1000
    g56
    m98 p1000
    g57
    m98 p1000
    m30
    o1000 (subroutine)
    Your G-code
    m99
    o1000 (Sub routine)
    Pretend this is G-code and writes
    G1 "John S is an Old Twat . .LMAO"
    M99 (End sub)
    I was going to say, less of the old, but I am old, I can't say less of the twat so I'll just have to chalk this one up to experience..............
    John S -
    You know your my Hero Old Man and taking the Piss out of the ultimate piss taker is meant with great respect. .
  5. #15
    Yup.
    Use the repeat command, 5th up from the bottom on the left, three diamonds, looks like a Renault badge but unlike a Renault it works.
    John S -
  6. #16
    Tenson's Avatar
    Brilliant John, thank you!
    I realise it's still worth learning about G54 offsets and stuff though.
  7. #17
    Never used Dolphin but Isn't that just to repeat multiple parts in a grid pattern not actually nest one part into piece of material many times.?
    Could just use Copy & paste and rotate to do that.!!
  8. #18
    Tenson's Avatar
    If I did copy and paste, it would just cut the part in the same place, wouldn't it? Anyway the part is rectangle so I've no problem with cutting on a grid.
  9. #19
    No it would cut were ever you paste it down. Most CAD/CAM programs give you as way to copy and layout multiple copies of the same part or bits of it. Bobcad calls it translate others will be different names.!
    True nesting you can select multiple parts tell it how many of each and the separation required then the nesting function will either lay them out in a grid or if odd shaped rotate to make best use of the material.
    This is great for instance when cutting say different Letters or numbers out of one sheet has each letter will be different shape a grid pattern would be very wasteful. The nesting function will twist and place them to extract the most out the sheet and will even place smaller items inside the waste of another part IE: e from the centre of O.!!
    Also very handy if your unsure how many parts you'll get out of sheet of material because it will tell you exactly.!! This is why often nesting is an upgrade or only in the Pro version.
    How many do you want to cut.? Out of what size material.?
    Has an exercise if you don't mind posting the G-code I'll see if I can make parametric code so you enter required number of pieces and material size along with part separation and the code does the rest.?
  10. #20
    I'm way too lazy to learn g-code in any great detail, so to do multiple parts, I use cambam's nesting feature which makes it piece of p15s to do multiple copies (& saves many a tool change too)
  1. Anyone got some 2.5D G-code please ?
    By dudz in forum Programmers Corner
    Last Post: 22-06-2013, 10:21 PM
  2. Cambium Code Web Tools Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 03:56 AM
  3. Mach3 Using a physical button to repeat current gcode
    By RLKS Rob in forum Artsoft Mach
    Last Post: 12-08-2012, 12:30 PM
  4. Use a tile cutter as a hobby table saw?!!!
    Last Post: 21-07-2009, 05:56 PM
  5. G Code help
    By moose007 in forum Programmers Corner
    Last Post: 22-05-2009, 10:39 AM
