Thread: Dc servo driver
Page 2 of 2 FirstFirst 12
    Hi all,
    I have spent another couple of hours tinkering with this driver, It apepars that pin 4 accepts a pwm signal which controls the speed rather than setting a position, and that pin 3's is used to vary the torque, IE when grounded the motor increases speed alot.
    Could do with a guide! figuring out electronics for noobs lol.
    After doing alot of reading, the motor has hall sensors + an encoder (2 wires) + wires to windings. So I assume that if there is an encoder then either that information is made available via an I/O or it must accept a position signal?
    Any help or Tips / ideas most welcome!
    Cheers,
    Sam
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Has been a member for 9-10 years. Has a total post count of 2,147. Received thanks 236 times, giving thanks to others 5 times.
    I'd guess it's most likely an analogue servo drive that takes +/-10V to control the speed, however they generally wouldn't need to see the motor encoder, as the motion controller would deal with the position side. Unless it's a motor with built in field sensors that the drive needs to see inorder to actually power the motor correctly (I'm having a complete blank about the proper name of this style of motor!).
    Any chance of some pictures of the motors?
  1. AC servo motor help !
    By rnr107 in forum Stepper & Servo Motors
    Last Post: 10-08-2015, 01:37 PM
  2. Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
    By george uk in forum Motor Drivers & Controllers
    Last Post: 23-06-2014, 07:38 PM
  3. Replies: 1
    Last Post: 16-03-2014, 06:29 PM
  4. 400W servo - Leadshine ACS806 + ACM604V60 driver - PSU size?
    By dsc in forum Stepper & Servo Motors
    Last Post: 23-04-2013, 04:33 PM
  5. re servo encoder
    By Scott in forum General Electronics
    Last Post: 24-06-2010, 07:30 AM
