Thread: Cut quality
    looks like you need to hurry up and sell some stuff... chewing on aluminium cant be good for your teeth..
    The chips aint too bad with a bit of warm milk!
    I really do need to get them sorted out out and sold off. Had them for a while now and havent gotten round to it. Thats what I get for doing non paying jobs I suppose.
    oscar's Avatar
    Lives in Oxford, United Kingdom. Last Activity: 19 Hours Ago Has been a member for 5-6 years. Has a total post count of 57. Received thanks 2 times, giving thanks to others 1 times.
    As others have said, looks like chip recutting.
    Did you run a spring/reflex cut to finish? If not this may help tidy it up a bit, depending how deep the damage at the top is.
    Quote Originally Posted by oscar View Post
    I have never heard this term before. Is it the same as finish pass? If so then yes it had a 0.2mm finish pass at full depth cut.
  5. #15
    oscar's Avatar
    A spring cut is when you run the cutter around the part again after your finish cut so that the cutter isn't under any load.
  6. #16
    oscar's Avatar
    Silly question, but. What's the flute length of your cutter?
  7. #17
    Have you tried climb milling on your finishing pass? G.
  8. #18
    Oscar the cutter flute length is 27mm.
    Geoffrey I would need to check the file to see how it was milled. Does climb milling improve the surface finish much?
  9. #19
    oscar's Avatar
    That's ok then. It's not the shank rubbing.
  10. #20
    oscar's Avatar
    I climb mill on everything, can't remember the last time I didn't. The finish is always good, if everything is set correctly. Also if the cutter does deflect its pushed away from the part, leaving metal safe (nothing a spring cut wont sort out). Rather than conventional milling where the cutter can pull into the job making it undersized.
  1. Good quality pillar drill?
    By newtoid1986 in forum Machine Discussion
    Last Post: 19-04-2013, 12:40 PM
  2. Quality DTI - Manufacturers
    By dsc in forum Marketplace Discussion
    Last Post: 13-12-2012, 12:34 PM
  3. stainless steel fasteners - quality
    By dsc in forum Metalwork Discussion
    Last Post: 30-11-2012, 11:35 AM
  4. CMM Programmer/Quality Engineer
    By Excel in forum Opportunities Available & Sought
    Last Post: 22-02-2011, 04:57 PM
  5. NEW MEMBER: cubikoman needs to improve quality of his boardgame
    By cubikoman in forum New Member Introductions
    Last Post: 16-02-2011, 11:17 AM
