Page 2 of 2 FirstFirst 12
    Quote Originally Posted by CLaNZeR View Post
    Could you also point me to another set of G-Code that is posted free that other people can use for a Kress holder ? :)
    Sean.
    Looking at mine which was another thread, it wasn't done by CNC. The design is so simple it was done with a drill, hacksaw and the 43mm hole was put in with a boring head or could be done clamped to a faceplate on a lathe.
    The fancy shapes do nothing only remove metal that is better staying attached to act as a heat sink.
    John S -
    That's true Sean, I was just pointing out a way for the many folk who haven't got to the working machine stage and are still reliant on hand tools or limited power tools.
    John S -
    An old recent thread, but I found it because soon, I'm going to need to buy a 43mm mount (audioAndy has kindly lent me his Proxxon BFW 40/E which has a 43mm ring...he lent me the mounts too - but I'm going to need my own soon!)
    So, where's the best (read best value!), place to buy such a beast?
    I found this one....
    http://www.cnc-plus.de/product_info....lder-43mm.html
    Which they kindly shown the dimensions, so I've quickly CAD'ed it up (exact same dimensions, but I've just rounded a corner or two)...but I'm not sure my CNC is really up to milling such chunky Aluminium....
    I'm fairly new to CAD/CAM, but if anyone wants the G-Code just drop me a PM - I guess all you'd need all you'd need to do is change the feed rate & the Z depth to suit your own CNC machine & material. (I've assumed 20mm & a feed rate of 10mm per minute at a depth of just over 1mm per take ...as I've never milled Aluminium, so hopefully have err'ed on the side of caution!)
  1. machining aluminium with 1.5kW spindle
    By routercnc in forum Spindles & Drive Motors
    Last Post: 15-02-2014, 01:55 AM
  2. eBay: Kress 1050 FME-1 Spindle
    By viz in forum Items On eBay UK
    Last Post: 21-08-2013, 03:04 PM
  3. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 01:07 PM
  4. Secondary Kress spindle mount.. Does it exist?
    By fasteddy in forum Kress Milling Motors
    Last Post: 18-08-2010, 04:25 PM
  5. Kress Spindle Holder
    By GTJim in forum Kress Milling Motors
    Last Post: 25-05-2009, 06:02 PM
