    Anyone got any good suggestions for a cooling pump for a 2.2kw Chinese water cooled spindle?? Got a 25ltr plastic barrel for the water/anti freeze & thought a submersible pump would probably be the best bet although if it were a small enough pump it could get mounted on the back of the gantry I suppose. Just wondered what other people were using seeing as there seem to be quite a few people using these spindles.
    Any suggestions would be most welcome, well any to do with a cooling pump that is lol.
    If you want small, I keep using these, they are freakin' amazing
    Mini Water / Coffee Pump 24 GPH (P-25A) DC 12V | eBay
    On my small lathe, for cutting coolant, I use a small pond pump, which fills a tank and the excess overflows back into the reservoir. Thus I have a controllable constant height gravity fed system and the flow from the tank is controlled by a gas tap. Now I don't know what the demands for a water cooled spindle are, but my system is cheap and controllable and can easily supply up to 1.5 meters with a very small pump.
    Just my two pennuth.
    Cheers,
    Rob
  1. Suggestions please on a small desktop CNC, lead screws or belt drive?
    By Tanky_Turk in forum Linear & Rotary Motion
    Last Post: 02-02-2014, 02:07 PM
  2. Power Supply Suggestions please..
    Last Post: 30-01-2013, 05:37 PM
  3. Driver suggestions
    By Shinobiwan in forum Motor Drivers & Controllers
    Last Post: 04-03-2012, 02:54 PM
  4. Spindle cooling pump
    By p1lts in forum General Discussion
    Last Post: 04-11-2011, 12:58 PM
  5. PLC/Programmable chip suggestions
    By m_c in forum General Electronics
    Last Post: 02-04-2011, 03:40 PM
