Thread: Mold Making?
Hi guys,
I'm having some difficulty figuring out the best way to mold a two sided part. I should add that I'm completely new to this!
What I plan to do is machine a master on the CNC out of 100mm Polyurethane board and then make a mold box, placing the master in this, and filling with Silicone rubber. I should add that this is a large part measuring 950x180x100mm. I'm not sure what shore rating silicone to use for this. I'm guessing the 15 Shore A is far too soft for such dimensions? I'll be needing around 20kg for the mold so want to get it right since it'll be an expensive mistake if not.
The main problem though is figuring out how to get the rear side detail into the casting without trapping lots of air or distorting the flat rear side portion of the cast part. The way I've tackled it at the moment is to level fill the mold with the casting resin and that will form a guide for the rear and be perfectly flat. I guess I could leave out the rear details but that'll mean throwing this on the CNC to do that and wasting resin.
I've attached the front and rear views of the part along with the first half of the mold but I would be grateful for suggestions on how to tackle the second half of the mold.
Rear of Master:
Front of Master:
First half of the mold:
25-02-2013 #2
Speaker enclosure eh :-) nice! Just out of curiosity what drivers are you intending to use! ( i know its not advice on your question :-) ) ive been planing on making a pair or ATC100's with a solid milled front baffle out of aluminium, sculpted and then anodised black.
25-02-2013 #3
Do they need to be made in one piece or could you manufacture them in 2 halves & then bond the 2 halves together. Would probably make things easier especially as far as expelling air goes.
25-02-2013 #4
Depends on how invisible and well matched the joint is which is like asking do I have the experience and skill with molding to ensure that... hmmm I have my doubts!
I have thought about taking the existing mold design I have and suspending the rear parts over that leaving the rest open to avoid trapping air as much as possible.
25-02-2013 #5
Information and Practical Advice for Advanced Composites - Easy Composites have a butchers here, ive done abit of fibreglass moulding in the past and used the same method at these vids to very impressive results. That might be sufficient for your mould master.
25-02-2013 #6
Hmmm i might try giving ATC a call see if they will deal direct.
25-02-2013 #7
Sounds like a nice project you have planned there. Can't go far wrong with ATC.
These will use scanspeak tweeter, accuton midrange and peerless xls sub.
25-02-2013 #8
Very nice, do you use wilmslow audio for components?
25-02-2013 #9
Plastic injection mold making forum?
By gavztheouch in forum Moulding MachinesReplies: 26Last Post: 13-10-2022, 11:31 AM -
Making a little box
By mark84 in forum General DiscussionReplies: 5Last Post: 11-03-2014, 11:34 PM -
RFQ: aluminium mold making
By kell in forum Projects, Jobs & RequestsReplies: 1Last Post: 24-03-2013, 01:40 PM -
WANTED: Ice ball mold price question...
By tanstaafl in forum Items WantedReplies: 6Last Post: 20-09-2011, 10:57 AM -
Making a Jig
By Wobblybootie in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 06-06-2010, 11:17 AM
