	27-02-2013 #1hey guys.
 They both say for fiberglass PCB and carbon but whats the best?
 High helix or the raspy type?
 Here are the links
 Rasp
 PCB Carbide Router CNC RASP DIAMOND 3.175mm NEW x10 | eBay
 High helix
 pcb drill CNC Carbide 3.1mm Zero Hits copper aluminium carbon fibre UK freepost | eBay
 If you know of any better within this price range and within the UK please let me know
	27-02-2013 #2Hi, the helix cutters are listed as drills. Do you want to drill or rout? G.
	28-02-2013 #3I need to mill/rout however I have noticed that all their bits are called drills if there mills or drills :S
	28-02-2013 #4The helix cutters need to have a sharpened edges at the bottom and are usually referred to as end mills. If you want to try one, PM me your address and I will send you one. G.
	28-02-2013 #5I've used these for cutting PCBs to size. Gave a very clean finish. However I've been told that carbon fibre leaves luch more fine abrasive dust than glass fibre. In that case the tool apparently wear very fast and a burr type is better.
 5x 1/8'' Carbide CNC Double/Two Flute Spiral Bits 12mm | eBayLast edited by Tenson; 28-02-2013 at 01:00 AM.
	28-02-2013 #6Slightly on topic, where can you buy the sheet FR4 or similar fibreglass?
  FOR SALE: Carbon Fibre Sheet 2mm (all carbon 3k)By richie00boy in forum Items For SaleReplies: 11Last Post: 27-02-2015, 08:44 PM
  Steam Engine made of GLASSBy WandrinAndy in forum General DiscussionReplies: 2Last Post: 13-06-2013, 09:57 AM
  NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plateBy Tomcat in forum New Member IntroductionsReplies: 0Last Post: 03-03-2013, 01:43 PM
  Cutting/Milling Glass?By Tenson in forum Machine DiscussionReplies: 1Last Post: 12-04-2012, 10:10 PM
  Carbon fiber keyrings...By Jonathan in forum General DiscussionReplies: 4Last Post: 08-03-2011, 02:39 PM
