    I'm after an 80mm lathe chuck with 3 or 4 jaws and self centering. It's to replace the one on my micro lathe which is missing the external jaws.
    If no-ones got one I'll get this one.
    Thank you...
    That's cheap.
    Everything he's selling you can buy cheaper elsewhere Except the two chucks ?
    Makes you wonder why ??
    John S -
    Yeah it is a good price relative to everyone else...fell off the back of a lorry perhaps. Do you reckon they'll have poor run-out or just be no good then?
    Got no idea.
    you need to buy one and tell us.
    At least they are cheap
    John S -
    80mm Independant 4 jaw chuck | eBay is this what you need, 2 mins to go.
    Quote Originally Posted by Philly View Post
    No, I need it to be self centering. Thanks for looking anyway...
    If one doesn't come up by the end of next week I'll get the cheap one I linked to earlier.
    I have no idea what self centering is anyway, I know nothing about lathes. Which is why I was searching ebay for a mini one :) I think its time I got one rather than using the router in funny ways.
    Self centering means when you turn the chuck key all the jaws move at the same time. They're generally used when it's not critical to have the part concentric after taking it out of the chuck and putting back in, since most will only be repeatable to a few hundredths of a millimetre. If you do need to hold the part with virtually zero runout, then a 4-jaw independent chuck can be used as you can move each jaw separately and use an indicator to get the part on centre. They're also good for holding irregular shaped parts, but take longer than self centering chucks to set up.
    It's surprisingly not much more money to get a decent size lathe, and they perform much much better, so if you have the room it's worth considering.
    Any brand or model to look out for, I dont have massive amounts of space but should have enough for a mid sized lathe.
    D.C.'s Avatar
    Lives in Birmingham, United Kingdom. Last Activity: 05-01-2016 Has been a member for 4-5 years. Has a total post count of 326. Received thanks 30 times, giving thanks to others 24 times.
    Smart and Brown lathes come up occasionally on ebay for 500 - 2000, some of the best lathes ever made and would cost as much a house new. Downside is you have to figure out how to transport a ton and half of iron to your shed, which is why they are always cheap...
    You can always check on Lathes for lathes specs and they also have a for sale board.
  1. WANTED: 4" / 100mm lathe chuck
    By Jonathan in forum Items Wanted
    Last Post: 23-04-2012, 02:05 PM
  2. WANTED: 5" / 125mm Lathe chuck
    Last Post: 21-02-2012, 12:22 AM
  3. Mini Lathe - which collect type (& chuck) should I go for?
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 09-11-2009, 01:47 PM
  4. Mini Lathe - chuck key, long nose type sourceable?
    By HankMcSpank in forum Milling Machines, Builds & Conversions
    Last Post: 19-10-2009, 12:41 PM
  5. Anyone got a DXF file for a mini lathe chuck mount?
    By HankMcSpank in forum Open Source Designs & Plans
    Last Post: 14-08-2009, 09:34 PM
