    I'm loving this idea and looks like i'm the first
    here is a drawing for a motor mount i used for 1/2" ali plate. It was designed for use with a 425mm belt, 15 and 24 tooth HTD pulley. Hope somebody can make use it? i will chuck the code made for linuxcnc in metric plus the cambam file in the code section as well
    Attached Files Attached Files
  2. The Following User Says Thank You to Swarfing For This Useful Post:
  3. #2
    Here is the code for Linuxcnc (setup in mm), also the CamBam file if you wish to edit it and make changes. Just change the extension if you are using mach3 as it should work fine in that. It uses a 5mm carbide cutter for the whole routine. Warning spiral drilling of the screw holes will bing if not using flood coolant. I would cut the code to only go down a couple of mm to give you marks and drill those manually or change to suite. Code will cut two mounts with subtle differences as they were specific to me. Essentially the 1mm location hole for my machine but you should be able to remove that if not needed. I have to admit you are really on your own with this code and i'm sure many will say the same.
    Enjoy
  4. The Following User Says Thank You to Swarfing For This Useful Post:
  1. FOR SALE: Nema 23 4Nm Stepper Motor
    By Shinobiwan in forum Items For Sale
    Last Post: 07-02-2013, 02:15 PM
  2. RFQ: Nema 23 motor mounts
    By luke11cnc in forum Projects, Jobs & Requests
    Last Post: 06-10-2011, 02:21 PM
  3. FOR SALE: Nema 23 motor mount (MBA-12C)
    By D-man in forum Items For Sale
    Last Post: 09-12-2010, 11:39 PM
  4. WANTED: Nema 23 motor mount
    By D-man in forum Items Wanted
    Last Post: 29-06-2010, 07:36 AM
  5. WANTED: Wanted: Nema 23 motor mount
    Last Post: 26-06-2010, 09:56 PM
