    Here's a quick spreadsheet which generates random G-code rapid moves (so just G0) within a specified area. It's useful for testing your motor tuning since it will cause the machine to tend to move in all directions with rapid changes in direction. I find it works well if you try a few different areas, so try it with the area set to be the whole bed, another with it a small area (25mm squared for instance) and another to test mainly Z. That way you can be reasonably confident that the machine wont stall in any position on the bed, or when cutting small parts with high acceleration. I have attached a few pieces of example code.
    To use it just enter the co-ordinates in the blue cells, copy column A and save it in notepad. Then open the file on your machine.
    Attachment 8366
    (Currently can't attach .xls files here, so I changed the file extension to .txt - put it back to .xls and it will open in MS Excel or Open Office)
    Random screenshot:
Name:	random gcode.PNG
    Attached Files Attached Files
  2. The Following 4 Users Say Thank You to Jonathan For This Useful Post:
  1. Help withController dip switch settings and Mach3 motor tuning
    By liamo1991 in forum Motor Drivers & Controllers
    Last Post: 15-11-2013, 02:22 AM
  2. Cambium Code Web Tools Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  3. Help please with motor tuning mach 3.
    By Kevin1970 in forum Artsoft Mach
    Last Post: 13-06-2012, 10:22 PM
  4. Random Z-Axis plunge
    By gomako in forum Machine Discussion
    Last Post: 15-05-2012, 07:38 AM
