Thread: whats pump for spindle cooling
im using a pond pump which is a high flow pump but minimal pressure and its very weak
the bottle neck is the actual spindle 3kw
i like to change to a gear type pump that has a bit of pressure to it, any recommendations ?
(i have cleaned the spindle out, taken out the connectors , but there is nothing obvious blocking it)
16-12-2015 #2
If you use a better pump then the small pond pump, like a coolant pump with 200W or so, thats enough for your spindle.
Depending to the manufacturer you need a rustprotection in it and the liquid must have not less then 18°C or similiar to use.
I recommend a small liquid cooler from a watercooled Computer or small motorcycle to cool down the warm water.
Spindle Water Pump
By Tomnewry in forum Spindles & Drive MotorsReplies: 0Last Post: 11-08-2013, 01:05 PM -
Cooling pump suggestions
By martin54 in forum General ElectronicsReplies: 2Last Post: 13-02-2013, 09:07 PM -
water cooling options for spindle
By routercnc in forum Tool & Tooling TechnologyReplies: 24Last Post: 12-02-2012, 11:22 PM -
Spindle cooling pump
By p1lts in forum General DiscussionReplies: 3Last Post: 04-11-2011, 01:58 PM -
chinese spindle cooling
By johngoodrich in forum Tool & Tooling TechnologyReplies: 11Last Post: 03-08-2011, 11:19 AM
