    im using a pond pump which is a high flow pump but minimal pressure and its very weak
    the bottle neck is the actual spindle 3kw
    i like to change to a gear type pump that has a bit of pressure to it, any recommendations ?
    (i have cleaned the spindle out, taken out the connectors , but there is nothing obvious blocking it)
    If you use a better pump then the small pond pump, like a coolant pump with 200W or so, thats enough for your spindle.
    Depending to the manufacturer you need a rustprotection in it and the liquid must have not less then 18°C or similiar to use.
    I recommend a small liquid cooler from a watercooled Computer or small motorcycle to cool down the warm water.
  1. Spindle Water Pump
    By Tomnewry in forum Spindles & Drive Motors
    Last Post: 11-08-2013, 01:05 PM
  2. Cooling pump suggestions
    By martin54 in forum General Electronics
    Last Post: 13-02-2013, 09:07 PM
  3. water cooling options for spindle
    By routercnc in forum Tool & Tooling Technology
    Last Post: 12-02-2012, 11:22 PM
  4. Spindle cooling pump
    By p1lts in forum General Discussion
    Last Post: 04-11-2011, 01:58 PM
  5. chinese spindle cooling
    By johngoodrich in forum Tool & Tooling Technology
    Last Post: 03-08-2011, 11:19 AM
