    Maybe the acrylic diffuser panels they use for the light units in paneled ceilings maybe a better bet?
    Composite board has a thin aluminium skin with a plastic centre. OK it's a lot more expensive than say far eastern ply but the whole thing would be lighter & easier to move about, it's already powder coated so no need to paint & comes in about 6 different colours plus it's pretty easy to cut so your woodworking guy could still manufacture it for you. Normal woodworking tools will be ok as long as any saws are fine toothed, for small jobs I use one of those throw away laminate saws that joiners use & the V groove I do with a normal hand help router.
    Not the cheapest way to do it but would look good & last for years.
    Most of the old clock radios and such like used (brown/green) tinted acrylic to reduce the glare.
    May if missed the point here but you can buy frosted vinyl no problem. If it needs cutting to a certain shape let me know and I will run it through my vinyl cutter
  5. #15
    With Birchy, it`s a contrast rather than diffusion problem, dark tint will work better than a frost.
    Amber LED might work better as well, high brightness, `sunlight visible ` are reliable and relatively cheap.
  6. #16
    Quote Originally Posted by Musht View Post
    I think your right about changing the LEDs for a different colour Bruce but not sure if that is still an option.
  7. #17
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Has been a member for 9-10 years. Has a total post count of 2,148. Received thanks 236 times, giving thanks to others 5 times.
    Changing the colour of the LEDs at this point isn't going to happen, as the only commonly available matrices use Red and Green.
    I'll see how the tinted perspex samples work out first.
  8. #18
    Green will appear brightest, but it`s the least reliable colour and is very sensitive to ESD.
  9. #19
    The perspex samples turned up last week, but I've only just got around to setting up a panel to try.
    Display Testing by mc_mtb, on Flickr
    The Frosted Slate Grey works pretty well, and only becomes illegible when I shine a 670lumen lamp directly at it, so it should be good once positioned suitably out of direct light with a hood.
    Only issue with the perspex is you've got to buy it in a complete sheet, which means it works out pretty expensive, especialy since I'll probably only need under quarter of a sheet, so I'm waiting for somebody to drop of some frosted vinyl samples, which I'll try on some clear perspex to see how it compares before making any decisions.
  10. #20
    window tint film springs to mind....
  1. Laminate plastic help!
    By totts in forum Marketplace Discussion
    Last Post: 13-04-2013, 06:14 PM
  2. What kind of machine will do stainless steel or brass engraving
    By JayPunchbuggy in forum Machine Discussion
    Last Post: 13-03-2013, 09:40 PM
  3. RFQ: Small parts from FR4 plastic - help!
    By James in forum Projects, Jobs & Requests
    Last Post: 12-06-2012, 03:02 PM
  4. 2 ply plastic help
    By h4ppy-chris in forum General Discussion
    Last Post: 30-01-2011, 03:54 PM
  5. Looking for thin plastic? sheet
    Last Post: 08-09-2010, 11:32 PM
