Hi all
I've assembled my Zapp Automation 3 axis stepper kit as per their instructions, the image and additional help from a thread here and the downloads from Zapp and I've got green lights where I expect green lights and a single red one for the power on the BOB.
The driver is the PM542 model.
The BOB is the ZP5A-INT Breakout board
(It is not currently fixed to the plasma table I will be building..)
So I'm happy with the wiring.
I've installed LinuxCNC on a spare PC and connected it via the parallel port to the BOB.
I now need to create configuration file which has me stumped. I don't know if I should be using a sample one or setting up a new one and if it is a new one what are the settings required, if it is a sample one... which???
I'm sure some else has been down this path before, so I'm hoping for a little help rather than reinventing the wheel..
Danny
24-03-2013 #2
24-03-2013 #3
Just start a new configuration for a 3 axis machine, unless you've messed with you par port keep the defaults. The breakout board will give you the info for the step/ dir pin settings. Just work through until you get stuck :-)
I think it is easier to set up that mach. Jonathan was mr pro mach until he admitted he now prefers linux from his previous beliefs that mach was the only one. Horses for courses.
What you waiting for GET ON WITH it!If the nagging gets really bad......Get a bigger shed:naughty:
24-03-2013 #4
Use the Stepconf Wizard, it's just a case of inserting the appropriate numbers. The main ones to get right are the step count (i.e. 800 steps if your drives are set to 800 steps on the dip switches) and the parallel port pin numbers.
As a heads up, have you ran the latency test yet? Because LinuxCNC uses a realtime kernel, it can be a bit fussy on hardware. Onboard graphics and WiFi cards are the main culprits. If you really need to use a wifi card, there's a possible solution (for geeks!) HERE.
25-03-2013 #5
I think the main problem for me is the whole new dictionary of phrases etc that mean very little to me at the moment. The learning curve seemed more of a wall, I was hoping that someone had scaled it before ...
I know I will have to get to grips the all the terms and phrases very soon, I guess I was being a little impatient to see some computer generated movement on the stepper..
I'll take the time to read the documentation I have and work through it slowly - but understanding each bit.
On the subject of the latency test, yes I have run it, for about 3 hours, the first 10 minutes REALLY abusing it and I got a bunch of numbers... That I noted down... but so far I have not seen a button to press to transfer them to somewhere to store (as I would expect) nor a field into which I should input them.. I guess I have missed something along the way and will have to revisit the wizard.
Watch this space, I'll post my progress so anyone following me may have a "cheat sheet" to get going quickly.
Danny
25-03-2013 #6
This is a good place to start: LinuxCNC Documentation - HTML version
And in particular, this: Stepper Quickstart
Problem with Zapp Automation website
By Shinobiwan in forum Marketplace DiscussionReplies: 17Last Post: 26-05-2014, 09:26 AM -
Zapp 3-Axis kit - putting it all together
By birchy in forum Motor Drivers & ControllersReplies: 5Last Post: 18-02-2013, 12:05 PM -
Zapp Automation CNC Driver Kit 4 Axis
By whensparksfly in forum Motor Drivers & ControllersReplies: 7Last Post: 01-03-2012, 01:54 PM -
10% Discount weekend At Zapp Automation
By Gary in forum Marketplace DiscussionReplies: 10Last Post: 19-02-2012, 12:42 PM -
Zapp Automation Discount Weekend !
By Gary in forum Manufacturer NewsReplies: 6Last Post: 21-08-2011, 11:29 PM
