Page 2 of 2 FirstFirst 12
    list of items left to get
    400w psu 36v power supply
    cnc micro switch
    end cap 75x75mm
    plus
    sbr 20 x 900 supported rail kit
    Quote Originally Posted by uppy121 View Post
    cnc micro switch
    end cap 75x75mm
    plus
    Hi there, it looks like you are going to get the supported rail then. It is best, but i managed for a while with unsupported, by the way i think you may be hitting the +Post New Thread button Rather than the +Reply To Thread button, Im sure one of the mods will put them all as one when they notice it.
    Rick
  3. The Following User Says Thank You to Ricardoco For This Useful Post:
  4. #13
    Presumably you've got the stepper drivers already, since they're not on your list, but which ones did you get? It looks like you have the common 3Nm motors. They work best with a lot more than 36V - ideally 70V. The reason is the inductance of the motor limits how fast the current can rise, so at high speeds the current can't reach the rated value, hence the motors don't output as much torque. However, by increasing the voltage you increase the rate at which the current rises, so that gets higher torque at higher speeds. If the drivers you've got will accept 50V, then you might as well get a 50V PSU instead of 36V. It will make a big difference.
    Already did it once...
  5. The Following User Says Thank You to Jonathan For This Useful Post:
  6. #14
    5 axis breakout board
    4 x drivers m542
    400 w power supply
    and yes 4 x 3 nm stepper motors
ID:	8584   Click image for larger version.
  7. #15
    Machine building in living room, second machine being planned before the first is finished. It seems to me you are a natural for this site. Well done. G.
  8. The Following User Says Thank You to GEOFFREY For This Useful Post:
  9. #16
    Sure is
    I must remember to shift that milling table out of the Utility room before the kids trip over it .....lol!
  10. The Following User Says Thank You to Swarfing For This Useful Post:
  11. #17
    Welcome to the forum, if you still need to buy a power supply for those drivers then as Jonathan has said you would be better off with a higher voltage, think those will run up to 50v unless your buying a second power supply because the one you have won't be enough for all the motors.
    Have a read through some of the build logs before you start buying new parts for the next build, it will give you a good idea of what will suit your needs best for the new machine.
    Best of luck with it.
  12. The Following User Says Thank You to martin54 For This Useful Post:
  1. NEW MEMBER: New to this forum, bristol
    By roygbiv in forum New Member Introductions
    Last Post: 08-01-2011, 03:01 PM
  2. NEW MEMBER: Hello all!!, Bristol England
    By Danimal in forum New Member Introductions
    Last Post: 10-09-2010, 08:31 PM
  3. NEW MEMBER: hello everybody, Bristol
    By HypnoToad in forum New Member Introductions
    Last Post: 08-09-2010, 11:11 PM
  4. NEW MEMBER: Hello from Bristol
    By matthewh101 in forum New Member Introductions
    Last Post: 09-11-2008, 11:13 PM
  5. NEW MEMBER: New Member - Bristol UK
    By spyder.boy in forum New Member Introductions
    Last Post: 05-10-2007, 08:33 AM
