Thread: Upgrade? Chinese CNC Machine
03-04-2013 #51
Once we have got both axis to move the same amount i can do the math again and give you the imperial equiv, then we can change the system to old school as like swarfing said it could be a yank model. but we will get it for you then of course that will rule out the mechanical and software stuff as the source of your trouble, leaving only the electrics but they may be fine and just need proper BOB and stepper drivers should you be so inclined..
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
03-04-2013 #52
03-04-2013 #53Cheers
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustarķa encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
03-04-2013 #54
confused but could be possible?
7.26TPI 0.13774" 3.499mm pitch is about as close as you could get to that. Stick with tuning it out for now like Rick said before. Imperial or not you would still like it working with what you have. Sorry i took this away from that.If the nagging gets really bad......Get a bigger shed:naughty:
03-04-2013 #55Cheers
Carl
03-04-2013 #56
Got to hit the sack, hope get somewhere soon
PaulIf the nagging gets really bad......Get a bigger shed:naughty:
The Following User Says Thank You to Swarfing For This Useful Post:
03-04-2013 #57
03-04-2013 #58
The Following User Says Thank You to Ricardoco For This Useful Post:
03-04-2013 #59Cheers
Carl
03-04-2013 #60
Why not get Mach to do the work for you ? go into "Settings tab", just above the reset button "set steps per unit" start with X enter 100 measure how far it moved then tell it how far it moved and will set steps up for you.
Do the same for all axis do a test cut if not correct go though it again.
Phill
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
Chinese CNC machine...whatchathink?
By HankMcSpank in forum Chinese MachinesReplies: 21Last Post: 11-04-2011, 05:21 PM
