    This question may be truely stupid but I have to ask.
    What does the resistor do that I have circled in red and is it something I need to add to the circuit?
    I thought you would directly conect the Breakout board to the drive.
    Jim
    Note: When VCC=5V, R=0
    When VCC=12V, R=1K, >1/8W
    When VCC=24V, R=2K,>1/8W
    R must connect in the control signal part .
    When using a BOB from a pp they are 5V output to the driver and therefore R = 0 and not needed if a controler is used that outputs a higher voltage then you have you use a current limiting R in the line...Clive
  3. The Following User Says Thank You to Clive S For This Useful Post:
  1. Resistor Calculator
    Last Post: 17-04-2012, 05:22 AM
  2. To usb,or not to usb,that is the question.
    By Jumbo in forum General Discussion
    Last Post: 17-10-2011, 09:21 PM
  3. ATX power supply - load resistor - do I need one ?
    By rckeith in forum General Electronics
    Last Post: 18-08-2010, 03:21 PM
  4. question ...
    By Wobblybootie in forum General Discussion
    Last Post: 04-01-2010, 12:04 AM
  5. What type of resistor?
    By Smiler in forum General Electronics
    Last Post: 05-12-2008, 10:04 PM
