Thread: IMO JAGUAR VFD help needed
13-04-2013 #31
TBH, I was also thinking that the machine needs a complete upgrade, particularly given the age and likelihood of capacitors being dried up. But then I figured that either money is very tight or this is some sort of retro build. If the budget is tight, then LinuxCNC on an old PC might be a better option.
13-04-2013 #32
Checked for voltage ...Stable 0.65 volts no change when trying to accelarate
13-04-2013 #33
Now I understand what you mean Birchy.
But at the moment I am not getting any voltage measurements at the machine speed control output
Maybe there is some fault there.
13-04-2013 #34
Yes, if it is a constant 0.65V throughout the selected speed range, then something is wrong. If that's the case, then maybe your original Parajust drive is OK but your CNC control is faulty?
14-04-2013 #35
This is quite probable? Is there anybody else here that can check against theirs?
14-04-2013 #36
Thank you both.
I am reading the Parker manual and it says ...\for Fast rotation requires pin 20 of 32 Pin input socket of SD2 drive to be connected to 0volts.
So I am now measuring the keyboard lines which leave the arrow button for manual jog, as the drive connecting socket not accessible, and is reading 4.8vdc.
When pressing the arrow button the test point voltage comes down to 0.650V
And when I keep this button pressed the screen shows the axis coordinates changing.
I must be totally blind I can't see what is going on. I must be real close solving this. Please note that I used a jumper wire to bridge the limit switch computer input to save some time testing limit switches. IF I do not do this the motors de-energize. Should i have done this or not?Last edited by asto; 14-04-2013 at 09:41 PM.
1 3/16"-16 tap and die needed
By dazza in forum Marketplace DiscussionReplies: 4Last Post: 26-12-2013, 05:36 PM -
Help needed connecting IMO JAGUAR VFD to Orac
By asto in forum Spindles & Drive MotorsReplies: 0Last Post: 09-04-2013, 08:05 PM -
help needed going to the next level
By luke11cnc in forum Computer SoftwareReplies: 8Last Post: 20-09-2012, 08:53 AM -
help needed for .drg files
By swinds in forum Machine DiscussionReplies: 0Last Post: 22-06-2011, 09:18 PM -
WANTED: Needed for my build
By jpcnc in forum Items WantedReplies: 9Last Post: 08-01-2011, 02:22 PM
