    djk's Avatar
    Lives in CHAMBERY, France. Last Activity: 23-02-2016 Has been a member for 8-9 years. Has a total post count of 9.
    Hi
    This is a new setup, Sanyo Denki stepper motors, Kinco 2M2280N high voltage drivers with a PMDX 126
    bob.I have a big problem with it. I cant run mach3 with it because I have 30 to 70 ACV on the stepper motor casings. Tested the stepper motors, there are no leaks. Dont know what to do, cheacked the wiring its ok. Thinking about changing the drives? or the lot
    Thanks for any help
    David
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    Have you got everything grounded correctly?
    djk's Avatar
    Everything is grounded correctly but the noise is playing havoc with mach3
    djk's Avatar
    Forgot to say I have the 70V when I take the earth of the motors, so where is it coming from. The only electical thing on the machine are the motors,
    Sounds like an earthing/sheilding issue, and as you're using 5V for signals, any shortcomings will quickly become apparent. That's why commericial machines use 24V for control circuits.
    The 70V is simply a result of what happens when you place a lump of metal next to something containing magnets and voltage.
    In you're wiring, have you inadvertantly created a ground loop somewhere?
    djk's Avatar
    With just one driver conected the problem is stil there.
    The high voltage side is wired correctly and control is
    The negative side of each PLS and DIR input to BOB ground
    PLS+ to step
    DIR+ to direction
    Getting ready to throw every thing out and get a closed loop stepper system
    Back to basics, have you used sheilded wiring, and tried to keep power and control wire routing as seperate as possible?
    And avoided having them run randomly across each other?
    djk's Avatar
    Sheilded wiring and power, control wires are seperate,a clean control box
    Make sure your shields are only connected at one end of the cable?
    I did have a link to a document that detailed grounding/sheilding, and how things should be wired, but I can't find it.
    Have a read over this thread - GROUNDING - what is the correct way to ground a CNC machine?
    Found it - http://www.automation.siemens.com/do.../emv_r.pdf?p=1
    Might take you a few reads to digest all the info, but explains things pretty well.
  1. stepper motors not being driven
    By sprint in forum Machine Control Software
    Last Post: 12-02-2013, 03:42 AM
  2. What power stepper motors do I need?
    By Monty_jon in forum Stepper & Servo Motors
    Last Post: 06-03-2012, 12:41 AM
  3. Help with Stepper Motors
    By Scott in forum Stepper & Servo Motors
    Last Post: 04-04-2010, 02:35 PM
  4. rs stepper motors
    By chaz@2b in forum Stepper & Servo Motors
    Last Post: 06-08-2009, 11:05 PM
